view not really closing [message #1611967] |
Wed, 11 February 2015 13:41  |
I have a weird problem which occurs from time to time (in the last time
more on Yosemite...).
I run an Eclipse based product as SWTBot test (Run As... JUnit Plugin
Test). First the test trues to close the welcome view. E.g.
@BeforeClass
public static void beforeClass() throws Exception {
bot = new SWTWorkbenchBot();
bot.viewByTitle("Welcome").close();
However, the view is not really close. Repeating the close command would
lead to an exception (view not found anymore). Since the view is not
really closed, all succeeding tests fail of course.
Do I miss anything? I already played around with bot.sleep but that did
not help. Any ideas?
Jens
Re: view not really closing [message #1613051 is a reply to message #1611967] |
Thu, 12 February 2015 06:24  |
On 11/02/2015 19:41, Jens v.P. wrote:
> @BeforeClass
> Cheers,
> Jens
Hi Jens
I had the same problem as well in the past; I saw in other projects that
the closing of the welcome view is put in a try catch and the widget not
found exception is ignored (but that requires waiting for the timeout).
In my projects' swtbot tests, I prefer to close the welcome view
programmatically (not with SWTBot specific methods), see for example
closeWelcomeView here:
https://github.com/LorenzoBettini/xsemantics/blob/master/tests/it.xsemantics.tests.swtbot/src/it/xsemantics/tests/swtbot/XsemanticsSwtbotTestBase.java
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.24779 seconds
