Home » Eclipse Projects » NatTable » Editable NatTable for GlazedLists?(Need to edit values in a GlazedList)
Editable NatTable for GlazedLists? [message #1564220] Wed, 14 January 2015 12:22 Go to next message
Hello!
I have been working with GlazedLists for the past few weeks and just recently found out that their default event table viewer does not allow for editing the table values. I started looking at NatTable this morning to replace it. Is it possible to edit the values of a NatTable that is backed by a GlazedList? If yes, is there a good NatTable example I can check out? I looked at the two GlazedLists and NatTable examples on GitHub, but I didn't see any reference to either JFace's CellEditor or GlazedLists WritableTableFormat.
If we get this working, I'm willing to contribute some example code back.
Jay
Re: Editable NatTable for GlazedLists? [message #1564274 is a reply to message #1564220] Wed, 14 January 2015 13:01 Go to previous messageGo to next message
There are NatTable examples on GitHub? I don't know them, so I can't tell anything about that. But if you are looking at our homepage https://www.eclipse.org/nattable/ you will find the NatTable Examples Application that can be executed via WebStart when clicking on the "Try it!" button.
In the official examples application you will find several examples regarding editing. There is also dedicated example for editing in conjunction with GlazedLists.
But there is one important thing to know. NatTable has its own mechanism for editing. There is no JFace CellEditor support, nor do we support such thing as the WritableTableFormat. The reason for this is that NatTable is a custom painted table control that has no relation to a native SWT table.
To get started with NatTable you might want to give the new Getting Started Tutorial a try I published a few days ago: http://www.vogella.com/tutorials/NatTable/article.html
The editing tutorial is work in progress, but you will find some basic information on our website: https://www.eclipse.org/nattable/documentation.php?page=editing
Re: Editable NatTable for GlazedLists? [message #1564600 is a reply to message #1564274] Wed, 14 January 2015 17:14 Go to previous messageGo to next message
Thanks Dirk! I'll check it all out and post what I come up with in the end.
As for the GitHub examples:
https://github.com/eclipse/nebula.widgets.nattable/tree/master/org.eclipse.nebula.widgets.nattable.examples/src/org/eclipse/nebula/widgets/nattable/examples/_600_GlazedLists
Re: Editable NatTable for GlazedLists? [message #1565118 is a reply to message #1564600] Thu, 15 January 2015 00:15 Go to previous messageGo to next message
Oh, these are the official examples. I wasn't aware that they are also hosted on GitHub.
I think the editing example with GlazedLists is located in the integration section. And the editing examples are located in the configuration section
Re: Editable NatTable for GlazedLists? [message #1697396 is a reply to message #1565118] Wed, 03 June 2015 11:15 Go to previous message
I finally got around to hooking Nattable up. It was straightforward and mostly followed the examples. Here's the code:
https://github.com/eclipse/ice/blob/jay/reflectivity/src/org.eclipse.ice.client.widgets/src/org/eclipse/ice/client/widgets/ListComponentSectionPage.java
We are in the process of pulling that code out into a reusable composite.
Thanks again for the help Dirk!
Previous Topic:Putting multiple hyperlinks inside a cell
Next Topic:Multi edit in Menu options
Current Time: Mon Jul 21 02:21:27 EDT 2025
Powered by FUDForum. Page generated in 0.04755 seconds
