Home » Eclipse Projects » SWTBot » SWTBotTreeItem's context menu click gives TimeoutException(SWTBotTreeItem's context menu click gives TimeoutException)
SWTBotTreeItem's context menu click gives TimeoutException [message #1416063] Thu, 04 September 2014 04:50 Go to next message
I was using swtbot 2.0.5. Recently I've started using swtbot 2.2.2 on eclipse 4.4.
I observed that SWTBotTreeItem's contextmenu click is giving TimeoutException.
My test-snippet is very simple-
SWTBotTreeItem ti = bot().tree().getTreeItem("i");
ti.contextMenu("Disable").click();
Here I'm getting 'SWTBotTreeItem ti' correctly. It's context menu 'Disable' is enabled in UI.
org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find context menu with text 'Disable'
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:Action must not be null
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.jface.action.ContributionManager.add(ContributionManager.java:76)
at org.eclipse.debug.internal.ui.views.expression.ExpressionView.fillContextMenu(ExpressionView.java:89)
Has anyone faced such problem?
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1416222 is a reply to message #1416063] Thu, 04 September 2014 11:47 Go to previous messageGo to next message
> at
> at
This stack doesn't seem related to SWTBot. You should check what can be
a cause of this error.
But it might also be in bug in SWTBot not sending the right menu event...
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1417555 is a reply to message #1416222] Fri, 05 September 2014 13:39 Go to previous messageGo to next message
This happens with swtbot 2.2.1 (or 2.2.2) + eclipse 4.4 combination.
Context menu click happens for swtbot 2.2.1 (or 2.2.2) + eclipse 3.7.2 combination.
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1422088 is a reply to message #1417555] Fri, 12 September 2014 05:58 Go to previous messageGo to next message
After debugging, I observed following things-
1. After launcing swtbot test, the debug views (e.g. Expressions) in Debug Perspective doesn't show any data, it comes only as white space with just 'Expressions' Tab. If I close the Expressions view and open it again (manually or through test) then it shows the data.
2. After stepping into the code for 'contextMenu', I observed that:
ExpressionView class in eclipse has a method 'fillContextMenu'. There it gets 'find' actionitem as null.
After exploring little more, I found that 'AbstractDebugView' class gets called for putting actionID for 'find' action for FoucusGained event. Again it gets called for FocusLost event and the 'find' actionID is removed from ExpressionView's fActionMap. After this sequence, 'fillContextMenu' is called where it doesn't get 'find' actionID because it's just has been removed..
Has anybody tried e4+swtbot 2.2.2 (or swtbot 2.2.1) combination?
The complete stack trace (with swtbot plugins) is as follows:
at org.eclipse.debug.ui.AbstractDebugView$2.menuAboutToShow(AbstractDebugView.java:556)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:352)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:492)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:487)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:519)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:255)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:782)
at org.eclipse.swtbot.swt.finder.finders.MenuFinder.findMenusInternal(MenuFinder.java:152)
at org.eclipse.swtbot.swt.finder.finders.MenuFinder.access$0(MenuFinder.java:149)
at org.eclipse.swtbot.swt.finder.finders.MenuFinder$2.run(MenuFinder.java:124)
at org.eclipse.swtbot.swt.finder.finders.MenuFinder$2.run(MenuFinder.java:1)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$2.doRun(UIThreadRunnable.java:140)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$1.run(UIThreadRunnable.java:89)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136)
... 25 more
JUnit fails with :
org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find context menu with text: Disable
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:412)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:386)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:374)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.contextMenu(AbstractSWTBot.java:444)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotTreeItem.contextMenu(SWTBotTreeItem.java:559)
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1422112 is a reply to message #1422088] Fri, 12 September 2014 06:40 Go to previous messageGo to next message
> gets 'find' actionitem as null. After exploring little more, I found
This is pretty interesting. I believe it's related to some of those
known bugs:
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=388306
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=363916
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=437915
Please add your analysis and suggestions to the bug that seems the most
related. I believe your experiments here can drive to a good fix.
Mickael Istria
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1425293 is a reply to message #1422112] Wed, 17 September 2014 01:11 Go to previous messageGo to next message
I've put my comments in bug 363916. I'm eagerly waiting for these bug fixes.
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1425613 is a reply to message #1425293] Wed, 17 September 2014 11:00 Go to previous messageGo to next message
> fixes.
The best way to get a bug fixed is not to wait, but to provide a patch ;)
http://wiki.eclipse.org/SWTBot/Contributing
Mickael Istria
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1429440 is a reply to message #1425613] Tue, 23 September 2014 04:28 Go to previous messageGo to next message
Please tell me if somebody knows about this-
In eclipse 3.7.2, it is seen that there were 2 actions-
1. find
2. find.Variables (declared in org.eclipse.debug.internal.ui.views.variables.VariablesView)
'find' action gets called on FocusGained or FocusLost events.
But 'ExpressionView.fillContextMenu' function looks for find.Variables event with the statement-
menu.add(getAction(VARIABLES_FIND_ELEMENT_ACTION));
It gets this action & the context menu click occurs even though 'find' action had been removed by FocusLost event.
In e4, fillContextMenu has the line- menu.add(getAction(FIND_ACTION));
e4 uses only one 'find' action which is also added/removed on FocusGained/FocusLost events and also looked for in fillContextMenu function.
Is this cause of the problem? Why is find.Variables action is removed in e4? Then how to deal with only one 'find' action?
Re: SWTBotTreeItem's context menu click gives TimeoutException [message #1471762 is a reply to message #1429440] Thu, 13 November 2014 05:06 Go to previous message
It seems I found how to make it work!
Actually the problem was caused due to not finding entry in fActionMap upon FocusLost event, which gets called as a result of SWTBotTreeItem.notifySelect().
If I comment out the line which sends SWT.FocusOut event in SWTBotTreeItem.notifySelect() method, then context menu click happens without any problem. UI also gets updated, as expected.
After commenting out this line, FocusLost routine of VariablesView in eclipse is not called and hence the globalActions (e.g. 'find' action) is not removed. Therefore, fActionMap gets entry for 'find' action in fillContextMenu() method of VariablesView and the further code also executes well.
Is this solution okay? Will it have any side-effects?
Please share your thoughts.
I've one more question--
If I compare implementation of notifySelect() method of SWTBotTableItem and SWTBotTreeItem, I see that-
SWTBotTableItem sends only SWT.Selection and SWTBotTreeItem sends a series of SWT events like MouseEnter, MouseMove, Activate, FocusIn and so on.
Are all these events required?
If I comment-out all events and keep only SWT.Selection in SWTBotTreeItem.notifySelect(), then also context menu click happens okay.
Is SWT.Selection alone not sufficient?
I'm not able to figure out the need for each event here. It would be very helpful if somebody explains it.
Thanks..
Aparna
Previous Topic:Anyone knows a way to click on submenus of a view menu?
Next Topic:@RunWith(SWTBotJunit4ClassRunner.class) won't catch screenshots on failure
Current Time: Sun Jul 20 21:45:03 EDT 2025
Powered by FUDForum. Page generated in 0.06009 seconds
