Home » Eclipse Projects » SWTBot » java.lang.Exception: Could not find plugin
java.lang.Exception: Could not find plugin [message #1391206] Mon, 30 June 2014 11:40 Go to next message
Hi All, i am Getting this java.lang.Exception: Could not find plugin Exception when i try to Run the Test from ant/Command line. I was Working with the Same few versions back and it was working fine that time.
I am using Eclipse 4.2 and latest swtbot 2.2.1,
I am not able to understand why this Problem is coming, because plugins are successfully deployed from Eclipse UI to plugins Folder.
Why it is not able to detect plugin, please help..
Following is the Exception i am getting..
Install location:
file:/c:/GoldenSource/Workbench_8.5.1_RC5/eclipse/
Configuration file:
file:/c:/GoldenSource/Workbench_8.5.1_RC5/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
file:/c:/GoldenSource/Workbench_8.5.1_RC5/eclipse/plugins/org.eclipse.osgi_3.8.0.v20120529-1548.jar
Framework classpath:
Debug options:
file:/C:/GoldenSource/Workbench_8.5.1_RC5/Automated_Runs/.options not found
Time to load bundles: 5
Starting application: 736
30 Jun 2014 21:01:52,508 INFO CommonPlugin:136 - Logger configuration starting......
30 Jun 2014 21:01:52,515 INFO CommonPlugin:140 - Plugin url = /
30 Jun 2014 21:01:52,723 INFO CommonPlugin:112 - Initialized logging for Goldensource workbench.
Testsuite: com.GS.CEN.TestCases.GSQA_MR_5050
Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 0 sec
Caused an ERROR
java.lang.Exception: Could not find plugin "com.GoldenSource.TestCases"
org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner$TestFailedException: java.lang.Exception: Could not find plugin "com.GoldenSource.TestCases"
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.runFailed(EclipseTestRunner.java:289)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:242)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.<init>(EclipseTestRunner.java:222)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.run(EclipseTestRunner.java:206)
at org.eclipse.swtbot.eclipse.junit.headless.UITestApplication.runTests(UITestApplication.java:116)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
at java.lang.Thread.run(Thread.java:744)
Caused by: java.lang.Exception: Could not find plugin "com.GoldenSource.TestCases"
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.loadSuiteClass(EclipseTestRunner.java:303)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.getTest(EclipseTestRunner.java:239)
Application Started: 3143
30 Jun 2014 21:01:54,126 INFO CommonPlugin:87 - Stopping Common plugin ...
[Updated on: Mon, 30 June 2014 11:46] by Moderator
Re: java.lang.Exception: Could not find plugin [message #1395828 is a reply to message #1391206] Mon, 07 July 2014 08:58 Go to previous messageGo to next message
Please any One Reply.. I am kind of Stuck with this Issue
Re: java.lang.Exception: Could not find plugin [message #1395855 is a reply to message #1395828] Mon, 07 July 2014 09:46 Go to previous messageGo to next message
"Could not find plugin" isn't really a SWTBot issue. It means that the
application you're starting is either missing this plugin or one of its
dependencies so the test cannot be loaded.
Make sure the application you're starting contains the bundle + all its
transitive dependencies.
Re: java.lang.Exception: Could not find plugin [message #1401263 is a reply to message #1395855] Tue, 15 July 2014 07:13 Go to previous message
Thanks Mickael for the Reply.
problem solved as i was missing some dependency in my Plugin which can be automatically added by Eclipse but i Command Line we need to add them in my Plugin.
Previous Topic:Ho do i invoke my SWTbot Test using Java Class
Next Topic:How do I launch a certain project in SWTBot Plug-in test?
Current Time: Fri Jul 25 08:37:50 EDT 2025
Powered by FUDForum. Page generated in 0.05560 seconds
