Home » Eclipse Projects » SWTBot » SWTBot cannot copy/paste on tree items using keyboard shortcuts
SWTBot cannot copy/paste on tree items using keyboard shortcuts [message #1384853] Mon, 02 June 2014 10:16 Go to next message
I want to copy/paste between two SWTBotTreeItem using CTRL+C/CTRL+V. Using copy/paste with the context menu works well, but I am required to use keyboard shortcuts too. The following code doesn't work: I can't copy the first node.
SWTBotTreeItem node1 = parentNode.getNode(name1);
SWTBotTreeItem node2 = parentNode.getNode(name2);
node1.select().pressShortcut(SWT.CTRL, 'C');
node2.select().pressShortcut(SWT.CTRL, 'V');
Even if I use 'copy' on node1 via the contextMenu, pressing CTRL+V on node2 does nothing.
I would like to understand what mistake I've done when using the pressShortcut.
Re: SWTBot cannot copy/paste on tree items using keyboard shortcuts [message #1384945 is a reply to message #1384853] Tue, 03 June 2014 05:06 Go to previous messageGo to next message
On 02/06/2014 16:38, David CHAUDET wrote:
> node2 does nothing.
> pressShortcut.
Which operating system are you using? I have a few problems with
testing keyboard shortcuts in Linux KDE: to avoid these issues I run
swtbot tests on another display (see the wiki) and use metacity as the
window manager in the other display.
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: SWTBot cannot copy/paste on tree items using keyboard shortcuts [message #1385182 is a reply to message #1384945] Wed, 04 June 2014 15:56 Go to previous messageGo to next message
Thanks for your answer.
I'm in Windows XP.
I don't understand when you talking about the wiki.
David
Re: SWTBot cannot copy/paste on tree items using keyboard shortcuts [message #1385261 is a reply to message #1385182] Thu, 05 June 2014 05:08 Go to previous messageGo to next message
> I'm in Windows XP.
> David
The wiki part I was referring deals with Linux I'm afraid :)
Xtext Book:
Re: SWTBot cannot copy/paste on tree items using keyboard shortcuts [message #1386240 is a reply to message #1385261] Sun, 15 June 2014 17:29 Go to previous message
Shame...
Thank you anyway!
Previous Topic:SWTBot Headless/Commandline Execution Failed
Next Topic:How to test collaboration/concurrency between two RCP application instances ?
Current Time: Sat Jul 26 21:03:34 EDT 2025
Powered by FUDForum. Page generated in 0.04893 seconds
