Home » Eclipse Projects » SWTBot » SWTBot hangs at click()
SWTBot hangs at click() [message #1384640] Thu, 29 May 2014 16:42 Go to next message
I'm trying to automate a simple new project wizard using SwtBot 2.2.1 . The code is the one that I've found in the tutorial
bot.menu("File").menu("New").menu("Project...").click();
The problem is that the click() method call never returns. My target platform is Eclipse Kepler on Linux x86_64 . The new project dialog is brought up however, so I'm not sure why the call does not return. Here's a screenshot of what the Eclipse instance under test looks like when the test hangs
http://i.stack.imgur.com/5H239.png
The stack trace of the main thread is
"main" prio=10 tid=0x00007f12c0006000 nid=0x428b runnable [0x00007f12c68d2000]
java.lang.Thread.State: RUNNABLE
at org.eclipse.swt.internal.gtk.OS.Call(Native Method)
at org.eclipse.swt.widgets.Display.sleep(Display.java:4233)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:802)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:117)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1416)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1401)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1187)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot$2.run(AbstractSWTBot.java:166)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$5.doRun(UIThreadRunnable.java:221)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable.run(UIThreadRunnable.java:78)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable.asyncExec(UIThreadRunnable.java:223)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.asyncExec(AbstractSWTBot.java:576)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.notify(AbstractSWTBot.java:155)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.notify(AbstractSWTBot.java:136)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.notify(AbstractSWTBot.java:126)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotMenu.click(SWTBotMenu.java:60)
at org.apache.sling.ide.test.impl.ui.NewContentPackageWizardTest.createNewContentProject(NewContentPackageWizardTest.java:55)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:47)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:44)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.rules.ExternalResource$1.evaluate(ExternalResource.java:48)
at org.junit.rules.RunRules.evaluate(RunRules.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:271)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
at org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner.run(SWTBotJunit4ClassRunner.java:54)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunner.main(RemotePluginTestRunner.java:62)
at org.eclipse.pde.internal.junit.runtime.PlatformUITestHarness$1.run(PlatformUITestHarness.java:47)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
- locked <0x00000000fe4fc480> (a org.eclipse.swt.widgets.RunnableLock)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3717)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3366)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.runApp(NonUIThreadTestApplication.java:54)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.runApp(UITestApplication.java:47)
at org.eclipse.pde.internal.junit.runtime.NonUIThreadTestApplication.start(NonUIThreadTestApplication.java:48)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
What can I do to make the test run successfully?
(also posted at https://stackoverflow.com/questions/23778686/swtbot-hangs-at-click , not sure if you watch stackoverflow for questions and thought I'd try here as well ).
Robert
Re: SWTBot hangs at click() [message #1384642 is a reply to message #1384640] Thu, 29 May 2014 17:29 Go to previous messageGo to next message
On 29/05/2014 22:42, Robert Munteanu wrote:
after click() is executed what does your test do? Is it getting the
shell corresponding to the dialog?
You say that it never returns because you're debugging it? In case
you're debugging it, then I think that method will never return because
you "stole" the focus to the Swtbot test....
> test hangs
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> (also posted at
> as well ).
> Robert
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: SWTBot hangs at click() [message #1384671 is a reply to message #1384642] Fri, 30 May 2014 04:11 Go to previous messageGo to next message
>> Hi,
> Hi
>> test hangs
Aaargh, nevermind. I was running the test as a JUnit Plug-In test and
'Run in UI Thread' was checked. Unchecking it makes the test work as
expected.
I only noticed the FAQ entry at [1] now, and I imagine I'm not the only
one. Would it be possible for SWTBot to assert early on that the test is
not running on the UI thread? I can open a bug if needed.
Robert
[1]:
https://wiki.eclipse.org/SWTBot/FAQ#Why_do_I_have_to_run_tests_as_SWTBot_tests.2C_instead_of_PDE-JUnit_tests.3F
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> (also posted at
>> as well ).
>> Thanks,
>> Robert
Re: SWTBot hangs at click() [message #1384703 is a reply to message #1384671] Fri, 30 May 2014 10:32 Go to previous messageGo to next message
>>> Hi,
>> Hi
>>> test hangs
> expected.
> Robert
> [1]:
Hi Robert
if you run the test using the SWTBot test launch instead of Plug-in test
launch it will take care of using the right thread
cheers
Lorenzo
Xtext Book:
Re: SWTBot hangs at click() [message #1385001 is a reply to message #1384671] Tue, 03 June 2014 10:23 Go to previous messageGo to next message
You could open a bug for that.
We could for example think of a @Rule to add on AbstractSWTBotTest that
would verify that test isn't running directly in UI Thread, and
fail/warn test otherwise saying "SWTBot tests should not run in UI Thread"
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: SWTBot hangs at click() [message #1398956 is a reply to message #1385001] Fri, 11 July 2014 17:15 Go to previous messageGo to next message
Filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=439458 .
Robert
Re: SWTBot hangs at click() [message #1398957 is a reply to message #1385001] Fri, 11 July 2014 17:16 Go to previous message
Robert
Previous Topic:Graphiti "drill-down" feature not executed on double click
Next Topic:Ho do i invoke my SWTbot Test using Java Class
Current Time: Wed Jul 23 14:15:40 EDT 2025
Powered by FUDForum. Page generated in 0.26370 seconds
