Home » Archived » Test and Performance Tools Platform (TPTP) » problems running with Ant.
problems running with Ant. [message #137603] |
Mon, 27 October 2008 20:12  |
I've integrated tptp with my product and can record and playback test cases
from within the product. When i run test cases via Ant they work as long as
they don't depend on the environment variables that my product needs being
set. Is there a way to set up the environment variables via ant .xml file?
Or some other mechanism?
thanks,
Matt
Re: problems running with Ant. [message #138173 is a reply to message #138165] |
Tue, 11 November 2008 06:31   |
Hi Matt,
> Java allows one to specify environment variables on the command line. Is
> the
> work that needs to be done just passing a string to the adapter thats
> running the test suite?
You can specify JVM arguments in your Ant script, such as:
<property name="tptp.automation.vmargs" value="[VM args]"/>
but these are passed to the JVM running Eclipse and NOT the JVM running the
test (e.g. test runner). Hence,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143121 .
> Also, my test cases work in standard mode because
> the environment appears to be set correctly but not when run via ant?
This is a common mistake when using the AGR since you have to ensure that
the playback environment is the same as the recording environment.
Paul
"matt murphy" <murphy@coherentlogix.com> wrote in message
news:gfa1s8$o44$1@build.eclipse.org...
> Hi Paul,
> the
> running the test suite? Also, my test cases work in standard mode because
> "Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
> news:ge6vnl$8fp$1@build.eclipse.org...
>> Hi Matt,
>> Unfortunately, there is no means to pass environment variables to the
>> JVM that is executing the test (different from the Eclipse and Ant JVMs).
>> See TPTP enhancement https://bugs.eclipse.org/bugs/show_bug.cgi?id=143121
>> for more details. If you are interested, please feel free to comment
>> and/or contribute to this enhancement.
>> Paul
>> news:ge5lcj$jba$1@build.eclipse.org...
>>> Hi,
>>> cases from within the product. When i run test cases via Ant they work
>>> as long as they don't depend on the environment variables that my
>>> product needs being set. Is there a way to set up the environment
>>> variables via ant .xml file? Or some other mechanism?
>>> thanks,
>>> Matt
Re: problems running with Ant. [message #138180 is a reply to message #138173] |
Tue, 11 November 2008 12:59   |
Hi Paul,
given the number of bugs there is no way to ensure the playback environment
is the same as the recording environment! I've spent weeks trying to work
around one issue after another. I've been successful at testing some of our
code but we have eclipse plugins that use the JNI and I don't think I have a
way to successfully create the environment to run tests without modifyign
either the tptp code or our code.
Is this problem with playback documented anywhere besides the bugs?
thanks,
Matt
news:gfbqfn$vj3$1@build.eclipse.org...
> Hi Matt,
>> the
> the test (e.g. test runner). Hence,
> Paul
>> Hi Paul,
>> the
>> because
>>> Hi Matt,
>>> JVMs). See TPTP enhancement
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=143121 for more details.
>>> If you are interested, please feel free to comment and/or contribute to
>>> this enhancement.
>>> Paul
>>>> Hi,
>>>> thanks,
>>>> Matt
Re: problems running with Ant. [message #138185 is a reply to message #138180] |
Wed, 12 November 2008 06:17   |
Hi Matt,
Within the TPTP project, bugs are only reported in Bugzilla
(https://bugs.eclipse.org/bugs/query.cgi). There are several queries for
the latest release at the bottom of this page:
http://www.eclipse.org/tptp/home/project_info/index.php?
In addition, user limitations are noted in the Release Notes for a
release. For example, for TPTP 4.5.x:
http://www.eclipse.org/tptp/home/downloads/4.5.0/documents/r eleasenotes/releasenotes4_5_0.html
Keep in mind, although the ASF is a 'GA' level component with full
test/support, the AGR is an 'As-Is' level component with no test/support:
http://wiki.eclipse.org/4.5_Component_Reorganization
Finally, I would encourage you (and your company) to contribute to the
TPTP project to help in resolving your blocking issues. TPTP is an
open-source project and will accept contributions from anyone, assuming they
follow the Eclipse Legal Process:
http://www.eclipse.org/legal/EclipseLegalProcessPoster.pdf
Paul
news:gfch6v$o59$1@build.eclipse.org...
> Hi Paul,
> environment is the same as the recording environment! I've spent weeks
> trying to work around one issue after another. I've been successful at
> testing some of our code but we have eclipse plugins that use the JNI and
> I don't think I have a way to successfully create the environment to run
> tests without modifyign either the tptp code or our code.
> thanks,
> Matt
>> Hi Matt,
>>> the
>> Paul
>>> Hi Paul,
>>> the
>>> because
>>>> Hi Matt,
>>>> the JVM that is executing the test (different from the Eclipse and Ant
>>>> this enhancement.
>>>> Paul
>>>>> Hi,
>>>>> thanks,
>>>>> Matt
Re: problems running with Ant. [message #138257 is a reply to message #138185] |
Mon, 17 November 2008 14:48   |
Hi Paul,
after writing some code to dump out the environment. It turns out that I can
work around the issues by setting the system environment variables on
windows.
thanks,
Matt
news:gfee11$jgb$1@build.eclipse.org...
> Hi Matt,
> they follow the Eclipse Legal Process:
> Paul
>> Hi Paul,
>> thanks,
>> Matt
>>> Hi Matt,
>>>> Is the
>>> that the playback environment is the same as the recording environment.
>>> Paul
>>>> Hi Paul,
>>>> Is the
>>>> because
>>>>> Hi Matt,
>>>>> Paul
>>>>>> Hi,
>>>>>> work as long as they don't depend on the environment variables that
>>>>>> my product needs being set. Is there a way to set up the environment
>>>>>> thanks,
>>>>>> Matt
Re: problems running with Ant. [message #138291 is a reply to message #138257] |
Tue, 18 November 2008 07:03  |
Hi Matt,
This is a great way to work around the limitation, albeit, requiring
these system variables on each target/remote machine.
Paul
news:gfshr9$mdn$1@build.eclipse.org...
> Hi Paul,
> can
> windows.
> thanks,
> Matt
>> Hi Matt,
>> Paul
>>> Hi Paul,
>>> and I don't think I have a way to successfully create the environment to
>>> run tests without modifyign either the tptp code or our code.
>>> thanks,
>>> Matt
>>>> Hi Matt,
>>>>> Is the
>>>> Paul
>>>>> Hi Paul,
>>>>> Is the
>>>>> because
>>>>>> Hi Matt,
>>>>>> Ant JVMs). See TPTP enhancement
>>>>>> details. If you are interested, please feel free to comment and/or
>>>>>> Paul
>>>>>>> Hi,
>>>>>>> test cases from within the product. When i run test cases via Ant
>>>>>>> they work as long as they don't depend on the environment variables
>>>>>>> that my product needs being set. Is there a way to set up the
>>>>>>> environment variables via ant .xml file? Or some other mechanism?
>>>>>>> thanks,
>>>>>>> Matt
Current Time: Sat Jul 26 02:51:45 EDT 2025
Powered by FUDForum. Page generated in 0.08468 seconds
