Home » Eclipse Projects » SWTBot » An example of opening an Eclipse perspective using SWTBot
| An example of opening an Eclipse perspective using SWTBot [message #13002] |
Fri, 09 January 2009 14:54  |
I just went through a trial an error session trying to figure out how I
could manipulate the Eclipse UI with SWTBot to open a perspective. Below
is a simple example of how to open the "Debug" perspective. I thought it
may be useful to others that may be getting started with creating tests
for Eclipse based products with SWTBot.
// Change the perspective via the Open Perspective dialog
bot.menu("Window").menu("Open Perspective").menu("Other...").click();
SWTBotShell openPerspectiveShell = bot.shell("Open Perspective");
SWTBotTable table = new SWTBotTable((Table)
bot.widget(widgetOfType(Table.class), openPerspectiveShell.widget));
table.select("Debug");
SWTBotButton OkButton = new SWTBotButton((Button)
bot.widget(widgetOfType(Button.class), openPerspectiveShell.widget));
OkButton.click();
I think it would be very useful to other test developers trying to use
SWTBot to test part various pieces of their Eclipse product if some
tutorials/guides were created that showed some real world examples.
Joe
| Re: An example of opening an Eclipse perspective using SWTBot [message #14084 is a reply to message #13231] |
Tue, 13 January 2009 11:14   |
Thanks for the tip, that results in a cleaner looking test.
Joe
Ketan Padegaonkar wrote:
> Also realized that you wrote a bit too much of code, you should never
> have to do a bot.widget, unless it's finding a widget that SWTBot does
> not support, or using a matcher that SWTBot does not have.
> openPerspectiveShell.activate();
> bot.table().select("Debug");
> bot.button("OK").click();
> -- Ketan
> On 10/1/09 01:24, Joe Luebker wrote:
>> Hello,
>> OkButton.click();
>> Thanks,
>> Joe
| Re: An example of opening an Eclipse perspective using SWTBot [message #14101 is a reply to message #14084] |
Tue, 13 January 2009 11:47   |
You may be interested in the patch that David filed
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=260623)
It will make your code a one liner:
Eclipse.workbench().switchToPerspective("Debug");
Expect this api to evolve and stabilize over a few weeks, and any inputs
are always welcome.
-- Ketan
> Joe
>> -- Ketan
>>> Hello,
>>> OkButton.click();
>>> Thanks,
>>> Joe
| Re: An example of opening an Eclipse perspective using SWTBot [message #14135 is a reply to message #14101] |
Tue, 13 January 2009 17:10  |
Very nice. I created a utility class in my development project to do
just that. I can switch to using the convenience APIs added as a fix for
that bug once they are complete. Looks like the bug is fairly active and
the changes will be quite large. Maybe once the work is complete a
summary of the added APIs should be posted somewhere since they should
make it even easier to create tests for Eclipse based projects.
Joe
> are always welcome.
> -- Ketan
>> Joe
>>> -- Ketan
>>>> Hello,
>>>> Below
>>>> thought it
>>>> OkButton.click();
>>>> Thanks,
>>>> Joe
Current Time: Fri Nov 07 20:55:15 EST 2025
Powered by FUDForum. Page generated in 0.05332 seconds
