Home » Archived » Test and Performance Tools Platform (TPTP) » Importing JUnit Tests into a TPTP JUnit Test
Importing JUnit Tests into a TPTP JUnit Test [message #121945] Mon, 04 February 2008 11:09 Go to next message
Hi All,
I have to import the JUnit Tests into a TPTP JUnit Tests.I have installed
eclipse Version: 3.0.2.
As per the instructions in the
"Eclipse documentation - Archived Release
Eclipse 3.1.2 "
When I select File/Import/JUnit tests to TPTP , I dont see the option
JUnit tests to TPTP . is it becuase of the eclipse version mismatch ?
3.0.2 is the installed version , but the documentation version is 3.1.2?
DO I have to install 3.1.2 in order to use the above feature or can I just
upgrade a specific plug-in , Please let me know.
Saran
Re: Importing JUnit Tests into a TPTP JUnit Test [message #122014 is a reply to message #121945] Mon, 04 February 2008 12:56 Go to previous messageGo to next message
Hi Saran,
This feature is only supported in TPTP 4.1.0.1
( http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.1.0. 1.html), which
requires Eclipse 3.1.2. You can install the TPTP features separately.
Paul
"Saran" <saravanan.subramanian@cmegroup.com> wrote in message
news:27a7eeaf716459b9d51c4d300b821c75$1@www.eclipse.org...
> Hi All,
> "Eclipse documentation - Archived Release Eclipse 3.1.2 "
> Thanks
> Saran
Re: Importing JUnit Tests into a TPTP JUnit Test [message #122065 is a reply to message #122014] Mon, 04 February 2008 13:32 Go to previous messageGo to next message
Hi Paul,
Another stupid question from a newbie,
If I copy the run time plugins (TPTP 4.1.0.1 ) will the new features show
up ? or I have to upgrade my eclipse client also Eclipse 3.1.2.?
Let me know. I just copied the above plugins and restarted clearcase,
still "import from Junit " option is not visible.
Saran
Re: Importing JUnit Tests into a TPTP JUnit Test [message #122156 is a reply to message #122065] Tue, 05 February 2008 06:25 Go to previous message
Hi Saran,
You can just copy the TPTP plug-ins, assuming you have the correct
dependencies. I would suggest consulting the TPTP download page for the
necessary dependencies and their versions
( http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.1.0. 1.html).
Paul
news:3afb5dcf69713ce31b4e2eb0e6d514fd$1@www.eclipse.org...
> Hi Paul,
> Thanks
> Saran
Previous Topic:Contribution to TPTP
Next Topic:AGR stacktraces but testcase passes
Current Time: Sun Jul 27 09:23:51 EDT 2025
Powered by FUDForum. Page generated in 0.03164 seconds
