Home » Eclipse Projects » SWTBot » Run/Debug launch of SWTBot Test fails(Unable to Run/Debug due to required plug-in 'org.eclipse.pde.junit.runtime' which is missing.)
Run/Debug launch of SWTBot Test fails [message #1123700] Wed, 02 October 2013 16:57 Go to next message
Is anyone having an issue where error message "Required plug-in 'org.eclipse.pde.junit.runtime' could not be found." is being displayed when trying to Run/Debug a SWTBot Test? I've seen this using Kepler 4.3 and Indigo 3.7.2.
I can't seem to get past this issue. Any help would be appreciated. This question has been asked before, but there no answer that works. Search stackoverflow.com for "required-plug-in-org-eclipse-pde-junit-runtime-could-not-be-found".
Re: Run/Debug launch of SWTBot Test fails [message #1124214 is a reply to message #1123700] Thu, 03 October 2013 05:47 Go to previous messageGo to next message
> and Indigo 3.7.2.
Which version of SWTBot are you using? How did you install it?
Also where do you get this error message? In logs of IDE, in logs of
runtime application, in UI...?
It looks like you target-platform configuration is missing something. If
you go in Debug Configurations, look for this debug config, go in tab
"Plugins" you'll see a "Validate Plugins" button. Click it and check
whether it tells you what you're missing.
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Run/Debug launch of SWTBot Test fails [message #1124435 is a reply to message #1124214] Thu, 03 October 2013 10:32 Go to previous messageGo to next message
I installed SWTBot version 2.1.1.201307101628 from the update site SWTBot - http://download.eclipse.org/technology/swtbot/releases/latest/.
I get the error message when I press the Debug icon in Eclipse. After that, a popup appears immediatly which says:
'Launching MyFirstTest' has encountered a problem.
When I go into Debug Configurations->Plug-ins tab, and click on Validate Plug-ins, the following problems are detected:
- org.apache.xmlrpc
  - Missing Constraint: Import-Package: javax.xml.bind; version="0.0.0"
I've attached the Eclipse error log and my configuration. Thanks for you help.
  • Attachment: log
    (Size: 0.82KB, Downloaded 304 times)
  • Attachment: configuration.txt
    (Size: 445.75KB, Downloaded 2190 times)
Re: Run/Debug launch of SWTBot Test fails [message #1125141 is a reply to message #1124435] Fri, 04 October 2013 03:39 Go to previous messageGo to next message
It looks like the issue is not in your Test configuration, but rather in
your IDE. Can you see the "org.eclipse.pde.junit.runtime" plugin
installed in your IDE? Does "Run as Plugin Test" command work?
Mickael Istria
Re: Run/Debug launch of SWTBot Test fails [message #1129608 is a reply to message #1125141] Tue, 08 October 2013 16:30 Go to previous messageGo to next message
The plugin "org.eclipse.pde.junit.runtime" is not installed in the IDE. I could not find it in the plgins directory under Eclipse.
Running the test as a Junit plug-in test or as a SWTBot test result in the same error message, "Required plug-in 'org.eclipse.pde.junit.runtime' could not be found".
Re: Run/Debug launch of SWTBot Test fails [message #1148554 is a reply to message #1129608] Mon, 21 October 2013 11:42 Go to previous message
I work with this Eclipse:
http://www.eclipse.org/downloads/packages/eclipse-ide-java-ee-developers/keplersr1
I think you just need to download swtbot from the
and it's suppose to work.
Previous Topic:Warnings on SWTBot tests
Next Topic:org.eclipse.swt.SWTException: Failed to execute runnable
Current Time: Sat Jul 26 03:13:29 EDT 2025
Powered by FUDForum. Page generated in 0.05536 seconds
