Home » Eclipse Projects » SWTBot » Target Platform configuration problem(How can I set an eclipse based application as target platform in order to be able to test on it?)
Target Platform configuration problem [message #825109] Tue, 20 March 2012 09:38 Go to next message
Hi guys,
I've been struggling for some days to set an eclipse based application, that has been developed with SWT as test environment for SWTBot. Unfortunately I had no success so far.
Installing the SWTBot plugins into the target platform is imposible due to its construction. So I tried to configure the target platform using the instructions from the "User's guide" but they are a bit bizarre and didn't help to much.
Maybe you could help me with some clear and simple steps I should follow so that SWTBot tests would run on my application.
Thanks!
Re: Target Platform configuration problem [message #1099884 is a reply to message #825109] Mon, 02 September 2013 06:48 Go to previous messageGo to next message
same issue with me,somebody can help us?
Re: Target Platform configuration problem [message #1100029 is a reply to message #825109] Mon, 02 September 2013 10:55 Go to previous messageGo to next message
What do you mean? "impossible due to its construction"?
What do you mean precisely by "a bit bizarre"? I'd be glad to turn them
is a clearer way if you give details about what isn't clear enough.
Did you read
http://wiki.eclipse.org/SWTBot/Automate_test_execution#Installing_headless_Testing_Framework
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Target Platform configuration problem [message #1122644 is a reply to message #825109] Tue, 01 October 2013 15:55 Go to previous message
On 20/03/2012 14:38, Ionut Trusca wrote:
> Hi guys,
> Thanks!
I always put org.eclipse.swtbot.eclipse and org.eclipse.swtbot.ide
FEATURES in my target platform without problems...
what problems do you experience?
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Previous Topic:WizardDialog waitCursor null when #stopped called
Next Topic:Internal Web Browser is not available when using SWTBot
Current Time: Wed Jul 23 04:51:13 EDT 2025
Powered by FUDForum. Page generated in 0.28850 seconds
