hanging on new SWTWorkbenchBot() [message #1111566] |
Wed, 18 September 2013 07:53  |
I'm newbie with SWTBot. I installed latest version 2.1.1 and junit 4.8.1 in Eclipse juno 4.2.2 on mac platform following http://wiki.eclipse.org/SWTBot/UsersGuide.
1) I could not add dependency to org.hamcrest. because in the SWTBot update-site, I could only find org.hamcrest.library and org.hamcrest.core This may have nothing to do with my issue, but I wanted to mention it, just in case.
2.a) When I run an extremely simple example like this one, it works fine:
import static org.junit.Assert.assertTrue;
import org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot;
import org.eclipse.swtbot.swt.finder.junit.SWTBotJunit4ClassRunner;
import org.junit.BeforeClass;
import org.junit.Test;
import org.junit.runner.RunWith;
@RunWith(SWTBotJunit4ClassRunner.class)
public class MyFirstTest {
@Test
public void alwaysTrue() throws Exception {
assertTrue(true);
2.b) But as soon as I add new SWTWorkbenchBot() either in the BeforeClass or Test as below, the code is hanging forever when I run it (using Run as SWTBot Test). I don't get any exception in the Console view.
private static SWTWorkbenchBot bot;
@BeforeClass
public static void beforeClass() throws Exception {
bot = new SWTWorkbenchBot();
@Test
assertTrue(true);
2.c) if I debug this code step-by-step using Debug as SWTBot Test. The code works ok without hanging and the eclipse instance launched by SWBot is closed properly.
Any idea where this could be coming from ? maybe any configuration step I've missed.
Many thanks in advance,
Benoît
[Updated on: Wed, 18 September 2013 07:53] by Moderator
Re: hanging on new SWTWorkbenchBot() [message #1111624 is a reply to message #1111614] |
Wed, 18 September 2013 09:29   |
[quote title=Mickael Istria wrote on Wed, 18 September 2013 15:05]On 09/18/2013
> Those Hamcrest bundles are on the SWTBot update-site, but they are not
> shown in installer. They are silently installed together with the SWTBot
> features or bundles which depend on them.
ok, I have installed the two features available in the update-site namely "Hamcrest Core Library Matchers" and "Hamcrest Library of Addiitonal Matchers" v1.3.0 (and thei
But, when I want to add the "org.hamcrest" plugin in the Dependencies of the manifest file (as mentioned in the UsersGuide page), the problem is that particular plugin (i.e. org.hamcrest) doesn't appear. I have the choice between org.hamcrest.core.source and org.hamcrest.library, is this normal ?
> What does happen if you use Debug as SWTBot but set no breakpoint?
> Is there any difference between you Run and Debug configuration.
no difference if I set no breakpoints, then the eclipse instance is hanging like when running it.
> A cause of locks in SWTBot are tests running in UI Thread (they shouldn't run in
> UI Thread).
I have read this in the documentation, but what does it mean concretely. you see my simple example + I run using Run as SWTBot Test. Is it enough ? or is there some other trick/configuration in order to run the tests outside UI thread ?
thanks,
Re: hanging on new SWTWorkbenchBot() [message #1112136 is a reply to message #1111624] |
Thu, 19 September 2013 02:55   |
> this normal ?
org.hamcrest doesn't exist. It's org.hamcrest.core.
And I guess the plugin selection dialog doesn't show them because they
are re-exported by some other dependency.
Anyway, feel free to bypass the dialog and open the MANIFEST.MF and add
those bundles as dependencies if you want.
Sorry, I don't have a clue. It seems to be specific to your use-case.
Maybe some concurrent work causing a deadlock.
> outside UI thread ?
Run as SWTBot Test is configured to always Run outside of UI Thread, so
it should be fine.
You can give a try to the "Run As Plugin Test" dialog (which does almost
the same thing and allow to control whether or not to run in UI Thread).
Maybe you'll get more luck or notice a small difference that will help
you to find the reason of this strange behavior.
Mickael Istria
My job: http://www.jboss.org/tools
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
FUDForum. Page generated in 0.05868 seconds
