Home » Eclipse Projects » SWTBot » Restarting Eclipse under test
Restarting Eclipse under test [message #1064873] Fri, 21 June 2013 09:42 Go to next message
I am using SWTBot to install a plug-in, and then restarting Eclipse. After the restart I want to continue testing (if plugin was correctly installed), but the test restarts and the plug-in is not installed anymore.
Is there any way around this? So I can continue testing after restart.
Thanks Smile
Re: Restarting Eclipse under test [message #1065265 is a reply to message #1064873] Tue, 25 June 2013 03:44 Go to previous messageGo to next message
Hi Asgeir Sognefest
is it possible in SWTBOT to restart eclipse ???
R u able to do the restart and start..
Re: Restarting Eclipse under test [message #1065420 is a reply to message #1064873] Tue, 25 June 2013 11:51 Go to previous messageGo to next message
As SWTBot starts inside Eclipse, it's not possible to have a test which
deals with the "Restart" process. When you restart, Eclipse stops, then
your SWTBot launcher stops, and Eclipse restart in its vanilla form,
without your SWTBot test being started.
What you can try instead of a restart is to separate your test suite in
2 pieces: one before restart and one after. You run your "before
restart" suite normally. When it ends, the uitestapplication will close
Eclipse, and then you run your "after restart" suite using the
uitestapplication again.
HTH
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Restarting Eclipse under test [message #1066401 is a reply to message #1065420] Tue, 02 July 2013 08:53 Go to previous messageGo to next message
Okay, I see.
Thanks Smile
Re: Restarting Eclipse under test [message #1069654 is a reply to message #1064873] Tue, 16 July 2013 06:09 Go to previous messageGo to next message
Hi Mickael,
I tried Using the Restart Functionality With SWTBOT in my Product and Found Some thing unusual, Following is My Test. So Every Time i Run this class File Swtbot is Running the Fist TestCase and Restart Eclipse and Start the Same Testcase again and Again...
It is Not Running the Second TestCase.
@Test
public void opennewSchedule() throws Exception
SWTWorkbenchBot bot = new SWTWorkbenchBot();
bot.Click();
bot.menu("File").menu("Restart").click();
@Test
public void opennewSchedule2() throws Exception
bot.menu("File").menu("Open").click();
Re: Restarting Eclipse under test [message #1069661 is a reply to message #1069654] Tue, 16 July 2013 06:22 Go to previous message
On 07/16/2013 12:09 PM, pawan garia wrote:
> Hi Mickael,
> Start the Same Testcase again and Again... It is Not Running the Second
> TestCase.
The restart functionality cannot be tested with SWTBot because "Restart"
will just restart Eclipse with the exact same options and won't continue
a Test Suite.
If you want to run a sequence of tests separated by restart, this has to
be implemented in the way you run those tests (Tycho Surefire, Bash,
Ant...) to actually run sequentially different test suites.
Just let the test suite run and close by itself, without using Restart.
Mickael Istria
JBoss, by Red Hat
Previous Topic:SWTBot 2.1.1 released!
Next Topic:Require-Bundle org.hamcrest
Current Time: Sat Jul 19 00:31:19 EDT 2025
Powered by FUDForum. Page generated in 0.05703 seconds
