Home » Eclipse Projects » SWTBot » SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2(SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2)
SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2 [message #1059163] Fri, 17 May 2013 01:09 Go to next message
SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2.
Code Snippet:
SWTWorkbenchBot bot = new SWTWorkbenchBot();
bot.toolbarButtonWithTooltip("Add SVN Repository").click();
Exception:
Could not find widget.
org.eclipse.swtbot.swt.finder.exceptions.WidgetNotFoundException: Could not find widget.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:357)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.widget(SWTBotFactory.java:308)
at org.eclipse.swtbot.swt.finder.SWTBot.button(SWTBot.java:289)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.run(EclipseTestRunner.java:350)
at org.eclipse.swtbot.eclipse.junit.headless.EclipseTestRunner.run(EclipseTestRunner.java:208)
at org.eclipse.swtbot.eclipse.junit.headless.UITestApplication.runTests(UITestApplication.java:116)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(WorkbenchTestable.java:71)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: Could not find widget matching: (of type 'Button' and with style 'SWT.PUSH')
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:407)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:381)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBotFactory.java:369)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntilWidgetAppears(SWTBotFactory.java:355)
Re: SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2 [message #1059823 is a reply to message #1059163] Tue, 21 May 2013 14:07 Go to previous messageGo to next message
Can you give a try to the latest snapshot build of SWTBot?
http://download.eclipse.org/technology/swtbot/snapshots/
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2 [message #1059876 is a reply to message #1059823] Wed, 22 May 2013 01:01 Go to previous messageGo to next message
Mickael,
I have also tried with latest snapshot build. But still getting the same error.
Re: SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2 [message #1060073 is a reply to message #1059163] Wed, 22 May 2013 18:17 Go to previous messageGo to next message
Hi Gourav,
I have the same problem too and cannot get it working.Looks like a bug.
Re: SWTBot 2.0.5 is unable to find toolbar button on Eclipse juno 4.2 [message #1060777 is a reply to message #1060073] Tue, 28 May 2013 08:12 Go to previous message
Yes, it could be a bug.
In such case, please report it to the bug tracker with as much details
as possible. If you want this to be fixed soon, you should also consider
contributing an automated test and a patch for the bug.
http://wiki.eclipse.org/SWTBot/Contributing
Mickael Istria
JBoss, by Red Hat
Previous Topic:Library.xml not exist in swtbot 2.1
Next Topic:No Classloader found for plug-in org.eclipse.jdt.junit4.runtime
Current Time: Sun Jul 27 11:49:11 EDT 2025
Powered by FUDForum. Page generated in 0.04156 seconds
