Library.xml not exist in swtbot 2.1 [message #1058212] |
Mon, 13 May 2013 04:56  |
Library.xml not exist in swtbot 2.1.
I installed swtbot 2.1 from latest update site in Juno 4.2 but there is no extracted folder of "org.eclipse.swtbot.eclipse.junit.headless_2.1.0.201302221524" to read library.xml for running headless. Do anyone has any idea how to run test cases headless in juno with latest version of swtbot.
Re: Library.xml not exist in swtbot 2.1 [message #1058234 is a reply to message #1058212] |
Mon, 13 May 2013 05:57   |
Thanks Mickael for your prompt reply. I extracted the bundle and run the test cases through ant script but i am getting below error
java.lang.RuntimeException: Application "org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplication" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.datatools.connectivity.console.profile.StorageFileEditor, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.importer.ecore.Ecore2GenModel, org.eclipse.emf.importer.java.Java2GenModel, org.eclipse.emf.importer.rose.Rose2GenModel, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer, org.eclipse.pde.build.Build, org.eclipse.pde.junit.runtime.uitestapplication, org.eclipse.pde.junit.runtime.legacytestapplication, org.eclipse.pde.junit.runtime.coretestapplication, org.eclipse.pde.junit.runtime.coretestapplicationnonmain, org.eclipse.pde.junit.runtime.nonuithreadtestapplication, org.eclipse.ui.ide.workbench, org.eclipse.wst.jsdt.core.JavaCodeFormatter, org.eclipse.wst.server.preview.preview, org.eclipse.swtbot.eclipse.core.swtbottestapplication, org.eclipse.swtbot.eclipse.junit.headless.swtbottestapplication.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
at org.eclipse.core.launcher.Main.main(Main.java:34)
Re: Library.xml not exist in swtbot 2.1 [message #1059265 is a reply to message #1058430] |
Wed, 15 May 2013 11:06  |
On 05/14/2013 07:34 AM, gourav mehta wrote:
> yes "com.testing.test" is my swtbot test plugin. I exported the same and
> copy "com.testing.test_1.0.jar" to eclipse/plugins folder but no luck.
> Still getting the same exception:
> java.lang.Exception: Could not find plugin "com.testing.test"
Copying is not the right way to install stuff in an Eclipse. You should
either use p2 director to install, or try to put it in the dropins folder.
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
FUDForum. Page generated in 0.06200 seconds
