Home » Eclipse Projects » Plugin Development Environment (PDE) » Programmatically export plugin(Wondering how to programmatically replicate exporting a deployable plugin)
Programmatically export plugin [message #1008144] Sun, 10 February 2013 17:39 Go to next message
Basically I am looking for a programmatic way to replicate the export deployable plugin wizard (without the wizard).
I need to take some eclipse projects and turn them into .jar files in exactly the same way as manually exporting them through the Eclipse wizard would (considering the manifest, build.properties etc.)
If anyone can give me any pointers to good examples etc, or a hint of where in the API to start I'd be very much obliged.
Re: Programmatically export plugin [message #1008263 is a reply to message #1008144] Mon, 11 February 2013 05:36 Go to previous messageGo to next message
I'm not very sure about what you're trying to achieve: is this something
you want in your IDE, or a headless build (command-line, Continuous
Integration friendly) ?
In case you want an Eclipse plugin, just mimic the action performed at
the end of the export wizard, and turn them into a command.
If you're looking for a headless build, I highly recommend you to use
Tycho, which relies on Maven to build your stuff. It's just a matter of
adding a pom.xml to your project in order to enable Tycho, and then
Maven+Tycho take care of everything (MANIFEST.MF, build.properties...)
to turn your projects into bundles.
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Re: Programmatically export plugin [message #1008299 is a reply to message #1008144] Mon, 11 February 2013 14:54 Go to previous messageGo to next message
It is possible to run org.eclipse.pde.internal.core.exports.PluginExportOperation programmatically, but it is not API. It is not documented and not guaranteed to exist in future releases.
You would be far better off using PDE Build or Tycho (as per Mickael's suggestion). The plug-in export in the UI is actually done using PDE Build.
Re: Programmatically export plugin [message #1008813 is a reply to message #1008299] Wed, 13 February 2013 17:37 Go to previous messageGo to next message
I need to start the process off from a plugin installed in Eclipse (basically just saving the time of actually using the export wizard). Most of the documentation I've come across for PDE Build or Tycho seems to suggest they're not setup for what I'm trying to do?
Re: Programmatically export plugin [message #1015749 is a reply to message #1008813] Sat, 02 March 2013 02:47 Go to previous message
you might also want to take a look at buckminster,
http://www.eclipse.org/buckminster/
HOME: http://www.lorenzobettini.it
Previous Topic:Invoke an eclipse plugin from a Java application
Next Topic:Improve existing debug view
Current Time: Thu Jul 24 23:10:10 EDT 2025
Powered by FUDForum. Page generated in 0.08506 seconds
