| View Toolbar button issue while SWTBot and Eclipse Juno [message #1006450] | Thu, 31 January 2013 06:29  |  |
| Eclipse User  |  |  |  |  | Hi,
 I'm using Eclipse 4.2 with SWTBot 2.0.5 for testing my application.
 On trying to click on a Toolbar button of a view, it's throwing ava.lang.NoSuchMethodError: org.eclipse.ui.internal.PartPane.getToolBar()Lorg/eclipse/swt/widgets/Control.
 Below is my code :
 // At this point, the active view returned is Breakpoint point view
 SWTBotView activeView = bot.activeView();
 // At this point, Breakpoint View has multiple breakpoints
 SWTBotToolbarButton toolbarButton = activeView.toolbarButton("Remove All Breakpoints");
 At the second line, the below exception is thrown :
 org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NoSuchMethodError: org.eclipse.ui.internal.PartPane.getToolBar()Lorg/eclipse/swt/widgets/Control;)
 at org.eclipse.swt.SWT.error(SWT.java:4361)
 at org.eclipse.swt.SWT.error(SWT.java:4276)
 at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
 at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
 at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
 at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
 at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
 at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
 at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
 at org.eclipse.swtbot.eclipse.core.UITestApplication.start(UITestApplication.java:54)
 Please let me know the possible way for resolving this issue.
 Thanks in advance,
 Syam
| Re: View Toolbar button issue while SWTBot and Eclipse Juno [message #1006544 is a reply to message #1006450] | Thu, 31 January 2013 10:49  |  |
| Eclipse User  |  |  |  |  | On 01/31/2013 12:29 PM, Syamananda Singh wrote: > Hi,
 > Below is my code :
 > SWTBotView activeView = bot.activeView(); // At this point, Breakpoint
 > Breakpoints");
 That kind of error is typical of an API incompatibility: the method with
 this signature used to be there and consumed by SWTBot or a dependency,
 and is not present any more in Eclipse 4.2.
 Could you please write a small test to reproduce this issue in the
 org.eclipse.swtbot.eclipse.finder.test plugin and open a Bugzilla to
 report it?
 http://wiki.eclipse.org/SWTBot/Contributing
 Mickael Istria
 JBoss, by Red Hat
 My blog: http://mickaelistria.wordpress.com
 My Tweets: http://twitter.com/mickaelistria
FUDForum. Page generated in 0.04017 seconds
