Home » Newcomers » Newcomers » Eclipse 3.3.1 crashes on launch
Eclipse 3.3.1 crashes on launch [message #247351] |
Thu, 31 January 2008 15:39  |
Greetings,
I downloaded eclipse-java-europa-fall2-linux-gtk.tar.gz for x86_64 and am
trying to run it on Debian Testing/Lenny running on AMD64. The 3.2.1 is
out of date for the software my team is using, and I need to be on 3.3.1.
I unzipped and ran /usr/local/eclipse/eclipse, and the following error
popped up:
JVM terminated. Exit code=13
/usr/bin/java
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
-jar
/usr/local/eclipse/plugins/org.eclipse.equinox.launcher_1.0. 1.R33x_v20070828.jar
-os linux
-ws gtk
-arch x86
-showsplash
-launcher /usr/local/eclipse/eclipse
-name Eclipse
--launcher.library
/usr/local/eclipse/plugins/org.eclipse.equinox.launcher.gtk. linux.x86_1.0.2.R331_v20071019/eclipse_1021.so
-startup
-exitdata 1b8004
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar
I have sun-java6-jdk and sun-java5-jdk and gcj 4.2.1-6. I've tried with
my /usr/bin executables pointing to jdk6 and gcj binaries, same result
both times.
I posted this problem in a different forum and it disappeared. Probably
my mistake but it was rather irksome looking for something that
mysteriously vanished.
Re: Eclipse 3.3.1 crashes on launch [message #247360 is a reply to message #247356] |
Thu, 31 January 2008 16:48   |
--------------090204090005090206080802
Walter,
I assume he didn't unzip over top of an older install since that's
likely not to work well...
Walter Harley wrote:
> "rektide" <rektide@gmail.com> wrote in message
> news:ad1293be8bd65280861601e3e46f2f6b$1@www.eclipse.org...
> Your original post is still visible to me, using Outlook Express, in
> eclipse.platform.
> I don't have an answer for you, though, other than "try specifying the VM
> explicitly on the Eclipse command line, and see if that helps."
<html>
<head>
</head>
Walter,<br>
<br>
likely not to work well...<br>
<br>
<br>
<blockquote cite="mid:fnte3o$i3a$1@build.eclipse.org" type="cite">
<pre wrap="">"rektide" <a class="moz-txt-link-rfc2396E" href="mailto:rektide@gmail.com"><rektide@gmail.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:ad1293be8bd65280861601e3e46f2f6b$1@www.eclipse.org">news:ad1293be8bd65280861601e3e46f2f6b$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">I posted this problem in a different forum and it disappeared. Probably
</pre>
</blockquote>
<pre wrap=""><!---->
eclipse.platform.
</pre>
</blockquote>
<br>
</body>
</html>
--------------090204090005090206080802--
Re: Eclipse 3.3.1 crashes on launch [message #247395 is a reply to message #247384] |
Thu, 31 January 2008 20:23   |
--------------070507010800000609070506
Walter,
I know. I think that as you get experienced you almost build up implicit
problem correcting steps that you might forget to spell out: like use
-clean, install in a fresh new location, or erase the old one first.
Then again who would erase the old one first; what if the new one
doesn't work! :-) My solution is: install a new Eclipse every couple
of weeks so I don't forget all the steps. Of course that's fine as
someone working on the latest stream walking forward in lock step with
the platform, but it's not realistic for users. Update manager seems
like a nightmare from hell, though I've never used it myself; but
apparently EMF is installed that way far more frequently than via people
unzipping zip files. I guess P2 will be a panacea. I can only hope. I
do have confidence in the people who say it will be good...
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fntfoq$hjt$3@build.eclipse.org...
>> I assume he didn't unzip over top of an older install since that's likely
>> not to work well...
> Good point! His path suggests that might be what happened.
> I swear, given all the questions like this that we answer on these
> newsgroups, I really wonder about the wisdom of not having an installer - at
> least something that could reliably unpack, check for the existence of a
> reasonable JRE, check path limitations, and check that the app isn't being
> installed on top of an old install. Maybe p2 does all that, but I think
> there is still a bootstrapping problem.
<html>
<head>
</head>
Walter,<br>
<br>
implicit problem correcting steps that you might forget to spell out:
like use -clean, install in a fresh new location, or erase the old one
first. Then again who would erase the old one first; what if the new
one doesn't work! :-) My solution is: install a new Eclipse every
couple of weeks so I don't forget all the steps. Of course that's fine
as someone working on the latest stream walking forward in lock step
with the platform, but it's not realistic for users. Update manager
seems like a nightmare from hell, though I've never used it myself; but
people unzipping zip files. I guess P2 will be a panacea. I can only
hope. I do have confidence in the people who say it will be good...<br>
<br>
<br>
<br>
<blockquote cite="mid:fntm12$gm$1@build.eclipse.org" type="cite">
<pre wrap="">"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fntfoq$hjt$3@build.eclipse.org">news:fntfoq$hjt$3@build.eclipse.org</a>...
</pre>
<pre wrap="">I assume he didn't unzip over top of an older install since that's likely
not to work well...
</pre>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
--------------070507010800000609070506--
Re: Eclipse 3.3.1 crashes on launch [message #247798 is a reply to message #247395] |
Mon, 04 February 2008 16:42   |
Ed Merks wrote:
> Walter,
Indeed I havent found any instructions for installing besides un-tar-gz,
cd, ./eclise. Even just making a page with something more helpful than
"unzip, run", one that covers problem cases, would probably be a good
start.
More problematically, when eclispe doesnt run, it doesnt give you any idea
what went wrong: the error messages for failed launch are completely
useless. I suspect if there were more instructive errors about what
failed, people would be a lot better able to trouble shoot on their. I
dont see any reason why eclispe cant throw some kind of error, rather than
an error code.
Update manager has always worked fine for my plugins.
Re: Eclipse 3.3.1 crashes on launch [message #247801 is a reply to message #247798] |
Mon, 04 February 2008 17:32   |
rektide wrote:
> Ed Merks wrote:
>> Walter,
>> fine as someone working on the latest stream walking forward in lock
>> step with the platform, but it's not realistic for users. Update
>> manager seems like a nightmare from hell, though I've never used it
>> myself; but apparently EMF is installed that way far more frequently
>> than via people unzipping zip files. I guess P2 will be a panacea. I
>> can only hope. I do have confidence in the people who say it will be
>> good...
> start.
> idea what went wrong: the error messages for failed launch are
> completely useless. I suspect if there were more instructive errors
> about what failed, people would be a lot better able to trouble shoot on
> their. I dont see any reason why eclispe cant throw some kind of error,
> rather than an error code.
A link to this page is featured on the Downloads page:
http://wiki.eclipse.org/SDK_Known_Issues
If it is the JVM that is crashing there is nothing Eclipse can do.
Eric
Re: Eclipse 3.3.1 crashes on launch [message #247807 is a reply to message #247801] |
Mon, 04 February 2008 17:52   |
>> start.
A link to what page?
I dont see anything on there that pertains to my issue. I'm not running
with gcj and the "unzip and run" did not work.
How about reporting the error the JVM tosses? (although frankly being
able to run on linux amd64 sun java6 doesnt seem outlandishly unreasonable
to me)
Re: Eclipse 3.3.1 crashes on launch [message #247893 is a reply to message #247807] |
Tue, 05 February 2008 09:03  |
>>> un-tar-gz, cd, ./eclise. Even just making a page with something more
>>> helpful than "unzip, run", one that covers problem cases, would
>>> probably be a good start.
>>> on their. I dont see any reason why eclispe cant throw some kind of
>>> error, rather than an error code.
You said:
"Even just making a page with something more helpful than "unzip, run",
one that covers problem cases, would probably be a good start."
I responded with the Known Issues page that covers, surprisingly, known
issues with running Eclipse. The issue you see is obviously not in that
category (or at least something about your system/environment is not in
the category of "known problem"), but I was just letting you know that
there is a page along the lines of what you were asking for.
Also, don't forget that Eclipse is open source, including the wiki; so
please do contribute to that page, if appropriate, when you find the
cause of the problem you are experiencing.
Eric
Current Time: Mon Jul 14 19:11:38 EDT 2025
Powered by FUDForum. Page generated in 0.15431 seconds
