Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » repost from stem-dev@eclipse.org
National Language Support [message #1885 is a reply to message #1869] |
Sat, 04 April 2009 07:00   |
Your Wiki page
http://wiki.eclipse.org/Welcome_STEM_Developers#National_Lan guage_Support
indicates, STEM supports other languages than English already.
Since STEM has been decided to remain "top level" Eclipse.org project, would
you also consider using Babel for that?
I know, for all base and extended Eclipse parts meant to be included with
Galileo this is an absolute MUST.
Being a somewhat independent RCP application, STEM may be under less
pressure here, but as this Eclipse project seems to work like most of the
others, registering with Babel and doing translations there does not seem a
problem.
You can also profit from Babel translations and translators. And a German or
French version of STEM (in Babel those are the 2 most active Western
"European" languages) would not only help you in Canada. Being usable in
their own countries and languages, scientists in those countries may also be
far more willing to participate and provide you the demographic data STEM
still is looking for in those countries.
On the other hand, since Babel already support Klingon, a special
"Californian English" would sure be very welcome for many geeks still in the
Silicon Valley, despite the world economic crisis.
Many of them certainly speak Klingon, too ;-)
Btw. any chance, STEM-like Geospacial models could be used to detect or
PREVENT such outbreaks, too ?!!!!)
Kind Regards,
Werner Keil
Language Champion (German) Eclipse Babel
(and the first guy to speak and write on OHF and STEM in Europe)
Re: National Language Support [message #1918 is a reply to message #1885] |
Mon, 06 April 2009 09:41  |
Yes, we did some initial work on supporting other languages in the code
base, including a special "California English" just to get things going.
This is actually quite important for the long term health of the project as
it is intended to be a "global platform" for collaboration on disease
modeling. It's not going to get there if it only supports English. Of the
current four committers, each is originally from a different country and we
speak three different native languages. One might think that there would be
three different language versions of STEM, but it isn't as easy as that.
There really needs to be someone who makes it their mission to enable NLS
support. The project probably needs an "NLS Manager".
Daniel Ford
IBM Almaden Research Center
San Jose, CA
"Werner Keil" <werner.keil@gmx.net> wrote in message
news:gr7el2$je4$1@build.eclipse.org...
> Your Wiki page
> would you also consider using Babel for that?
> a problem.
> or French version of STEM (in Babel those are the 2 most active Western
> be far more willing to participate and provide you the demographic data
> STEM still is looking for in those countries.
> the Silicon Valley, despite the world economic crisis.
> Kind Regards,
> Werner Keil
National Language Support [message #560587 is a reply to message #1869] |
Your Wiki page
problem.
Kind Regards,
Werner Keil
Re: National Language Support [message #560606 is a reply to message #1885] |
Daniel Ford
San Jose, CA
> Your Wiki page
> a problem.
> Kind Regards,
> Werner Keil
Current Time: Sun Jul 27 01:27:47 EDT 2025
Powered by FUDForum. Page generated in 0.03776 seconds
