Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EMFCP is crashing the eclipse workspace
EMFCP is crashing the eclipse workspace [message #1100539] |
Tue, 03 September 2013 08:26 |
Simon Stumps Messages: 8 Registered: April 2013 |
Hello together,
i am developing an eclipse rcp application and would like to use the EMFCP plugins. i started with this tutorial: eclipsesource.com/blogs/tutorials/getting-started-with-the-emf-client-platform/
after plugin installation, my eclipse opens a default workspace every time i start it and i am not able to change it back to save the last known workspace. at least the "switch workspace" option works fine.
In addition: after 1 or 2 starts eclipse takes more then 10 minuts to load the workspace.
i tryed to install the EMFCP plugins into a new eclipse with same results.
also: where is the bugtracker for the project? the link from the homepage (http://www.eclipse.org/emfclient/support.html) is a dead end.
any one else with this problem?
thanks
PS: I am using eclipse kepler and also tryed it with 4.2
[Updated on: Tue, 03 September 2013 08:59] Report message to a moderator
Re: EMFCP is crashing the eclipse workspace [message #1101234 is a reply to message #1100813] |
Wed, 04 September 2013 07:16 |
Hello again,
here is what i have done:
- http://eclipse.org/emfclient/gettingstarted.html -> step 1 download and then on the top right klicked the "the latest modeling edition" link and downloaded the "eclipse-modeling-kepler-R-win32-x86_64.zip".
- unpack and start
- then I used the eclipse update site under http://download.eclipse.org/emfclient/releases/102 to install all available packages:
picture(remove whitespace since i am under 5 posts): http:// i.imgur.com/kktlpbu.png
after restarting eclipse, I closed it and opened it again, the workspace was already changed and I had to manually change it back to the one I have chosen at the first start of this new eclipse. It looks like that the workspace location changes to C:/user/[username]/workspace. The workspace I have created only contains a .metadata folder with the typically ".mylyn", and ".plugins" folders, that's all.
Maybe you can reproduce it at your own computer.
Simon
edit: i could reproduce the problem on another computer.
[Updated on: Wed, 04 September 2013 07:19] Report message to a moderator
Re: EMFCP is crashing the eclipse workspace [message #1101514 is a reply to message #1101332] |
Wed, 04 September 2013 14:59 |
Jonas Helming Messages: 699 Registered: July 2009 |
I can reproduce this. I have created a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=416531
It has probably something to do with the initialization oder of
services, however hard to debug. I will try to fix this a soon as
possible. In the meantime, I hope this is no blocker for you. If you
want to avoid manually switching your workspace everytime you re-start,
you might want to define an explicit target platform and add ECP in
that. That allows you do deinstall it from the IDE as long as the issue
occurs.
Jonas
Am 04.09.2013 12:14, schrieb Jonas Helming:
> thanks, I am looking into it now...
> Am 04.09.2013 09:16, schrieb Simon Stumps:
>> Hello again,
>> - unpack and start
>> available packages:
>> Regards,
>> Simon
Re: EMFCP is crashing the eclipse workspace [message #1103236 is a reply to message #1101514] |
Fri, 06 September 2013 14:16 |
the issue should be fixed in 1.1.M1, I suggest you upgrade to this version.
http://eclipse.org/emfclient/download.html#milestone
Please tell me, if this resolves the problems.
Jonas
Am 04.09.2013 16:59, schrieb Jonas Helming:
> occurs.
> Regards
> Jonas
>>> Hello again,
>>> - unpack and start
>>> available packages:
>>> Regards,
>>> Simon
Re: EMFCP is crashing the eclipse workspace [message #1106513 is a reply to message #1100539] |
Wed, 11 September 2013 07:38 |
Hello Jonas,
i installed the update today and it fixed my problem.
but now my editor isnt working any more. i am opening the ECPEditor with openEditor(input, "org.eclipse.emf.ecp.editor", true); and before the update it worked pretty well but now i only get many null pointer exceptions.
edit: looks like the ViewContext is new. Can you update the doc?
[Updated on: Wed, 11 September 2013 08:14] Report message to a moderator
Re: EMFCP is crashing the eclipse workspace [message #1106553 is a reply to message #1106536] |
Wed, 11 September 2013 08:44 |
i already did that. but i have to use ViewContext in the new version, right? its also missing in the doc: https://hudson.eclipse.org/hudson/job/emf-emfclient-maintenance/531/artifact/git/bundles/org.eclipse.emf.ecp.doc/target/ecp-doc/index.html
i wrote my own EditorInput and now it has to implement public ECPControlContext createSubContext(EObject eObject) and public ViewModelContext getViewContext()
here is the error log (shortend)
at org.eclipse.emf.ecp.internal.ui.view.builders.NodeBuilders.build(NodeBuilders.java:116)
at org.eclipse.emf.ecp.internal.ui.view.builders.NodeBuilders.build(NodeBuilders.java:100)
at org.eclipse.emf.ecp.ui.view.swt.internal.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:96)
at org.eclipse.emf.ecp.ui.view.swt.internal.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:82)
at org.eclipse.emf.ecp.internal.editor.ViewModelEditorComposite.createUI(ViewModelEditorComposite.java:49)
at org.eclipse.emf.ecp.editor.internal.e3.MEEditorPage.createFormContent(MEEditorPage.java:125)
at org.eclipse.ui.forms.editor.FormPage$1.run(FormPage.java:152)
at org.eclipse.ui.forms.editor.FormPage.createPartControl(FormPage.java:150)
at org.eclipse.ui.forms.editor.FormEditor.pageChange(FormEditor.java:471)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1083)
at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEditor.java:603)
at org.eclipse.ui.forms.editor.SharedHeaderFormEditor.createPages(SharedHeaderFormEditor.java:103)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:358)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1096)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:66)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:576)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:605)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:585)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:539)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:528)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1026)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3120)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:3042)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:3024)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3020)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2984)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2975)
[Updated on: Wed, 11 September 2013 08:51] Report message to a moderator
Re: EMFCP is crashing the eclipse workspace [message #1106583 is a reply to message #1106573] |
Wed, 11 September 2013 09:26 |
In my MyECPControlContextImpl i use the new ViewModelContextImpl(getView(), getModelElement()); method to get a ViewContext. i use a copy from ECPControlContextImpl.getView() and there is the NPE.
private View getView() {
int highestPrio = IViewProvider.NOT_APPLICABLE;
IViewProvider selectedProvider = null;
for (final IViewProvider viewProvider : ViewProviderHelper.getViewProviders()) {
final int prio = viewProvider.canRender(getModelElement());
if (prio > highestPrio) {
highestPrio = prio;
selectedProvider = viewProvider;
if (selectedProvider != null) {
return selectedProvider.generate(getModelElement());
return null;
NPE is in the "final int prio = viewProvider.canRender(getModelElement());" line. Probably because i dont have a viewProvider
at org.eclipse.emf.ecp.view.model.provider.xmi.ViewModelFileExtensionsManager.hasViewModelFor(ViewModelFileExtensionsManager.java:139)
at org.eclipse.emf.ecp.view.model.provider.xmi.ExtensionXMIViewModelProvider.canRender(ExtensionXMIViewModelProvider.java:30)
at com.project.presentation.produktmodellierung.editor.MyECPControlContextImpl.getView(MyECPControlContextImpl.java:124)
at com.project.presentation.produktmodellierung.editor.MyECPControlContextImpl.<init>(MyECPControlContextImpl.java:47)
[Updated on: Wed, 11 September 2013 09:27] Report message to a moderator
Re: EMFCP is crashing the eclipse workspace [message #1106643 is a reply to message #1106583] |
Wed, 11 September 2013 11:04 |
looking at the line where the NPE is thrown let me assume, that the
model element is null (getModelElement()). Could you please check this?
getModelElement() should return the EObject to be opened.
However, in 1.1.M1, we provide a new API, which makes it much easier to
create an editor. We are planning to deprecate the ECPControlContext in
future versions. However, the new API does not yet support references
features yet. If your EObjects only have simple attributes, you can
already try it. It is documented here:
http://eclipsesource.com/blogs/tutorials/emf-client-platform-how-to-customize-the-editor-layout/
(last paragraph)
If you experience any more issues, you can also contact me on Skype if
you want: "JonasHelming"
Thanks for the feedback!
Jonas
Am 11.09.2013 11:26, schrieb Simon Stumps:
> is the NPE.
> highestPrio = prio;
> return null;
> at
> at
> at
> at
Current Time: Sat Jun 15 01:30:48 GMT 2024
Powered by FUDForum. Page generated in 0.04632 seconds
