Home » Archived » EPF » EPF Composer as Plugin
EPF Composer as Plugin [message #15277] Sun, 25 June 2006 23:49 Go to next message
Originally posted by: saba.kanagasabapathy.eds.com
Is it possible to have EPF Composer as plugin to Eclipse? I want to use my
existing installation of Eclipse and want the EPF Composer to be installed
as Plugin rather than separate installtion.
Saba
Re: EPF Composer as Plugin [message #15310 is a reply to message #15277] Mon, 26 June 2006 19:22 Go to previous message
Originally posted by: storaskar.xx.xxx.xxx
EPF Composer is a RCP application.
But since EPF is an open-source project, you can always get source code,
and export EPF plugins as an deployable features/plugins and drop it on
your existing eclipse application. OR alternative would be, if you
already have EPF composer installed you can get copy of
"org.eclipse.epf.xxx" plugins and features folders from EPF installation
and drop it on your existing eclipse application. Both of these do require
that your existing eclipse application have the same versions as EPF
requires. Please check developement environment setup and requirements for
EPF http://www.eclipse.org/epf/composer_dev_guide/dev_env.php
Re: EPF Composer as Plugin [message #564340 is a reply to message #15277] Mon, 26 June 2006 19:22 Go to previous message
Previous Topic:EPF Composer as Plugin
Next Topic:EPF Error - JVM Terminated
Current Time: Sun Jul 27 00:31:51 EDT 2025
Powered by FUDForum. Page generated in 0.05298 seconds
