Home » Newcomers » Newcomers » Callisto install without Update Manager
Callisto install without Update Manager [message #159359] Mon, 03 July 2006 10:32 Go to next message
Originally posted by: joseph.preston.kirtland.af.mil
I have development systems that have no internet access. How can I do an
install of the Callisto bundle without using Update Manger? Generally for
Eclipse installs, I download to an internet accessible system, and
transfer files over by hand-- burn CD or USB thumb-drive.
Thanks!
Re: Callisto install without Update Manager [message #159379 is a reply to message #159359] Mon, 03 July 2006 13:27 Go to previous messageGo to next message
Joe,
You can download the individual components you're interested in
separately from their respective websites, then unzip them all to the
same location and you should be good to go. Just be careful in making
sure you get all the required plug-ins for the stuff you're interested
in. For instance, if you want to install VE, you'll need to get GEF and
EMF too. The download page for each project should list their
requirements, if any.
Hope this helps,
- Jeff
Re: Callisto install without Update Manager [message #159402 is a reply to message #159359] Mon, 03 July 2006 14:13 Go to previous messageGo to next message
> for Eclipse installs, I download to an internet accessible system, and
> Thanks!
You're the "Joe" I ran into over on Bernie's blog, right? If so, you've
already found the link to <
http://www.yod.yoxos.com/geteclipse/W4TDelegate > I gave over there. And
now it's documented here as well in case someone else comes along
wanting the same thing! :-)
I have nothing to do with Yoxos... just ran across a link to them on
Bjorn's blog (< http://eclipse-projects.blogspot.com/ >) and thought I'd
pass it on.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: Callisto install without Update Manager [message #159409 is a reply to message #159379] Mon, 03 July 2006 14:39 Go to previous messageGo to next message
Jeff Myers wrote:
> Joe,
i think the point is.. Calisto does reference it's parts in text but
does not supply html-links to these named parts.
nor do projects allways supply html-links to their requirements.
> Hope this helps,
> - Jeff
on a side note.. Jeff, why not publish the scm & release db-uri publicly
iso f.i. those text-maps.
--Noud
Re: Callisto install without Update Manager [message #159415 is a reply to message #159409] Mon, 03 July 2006 15:11 Go to previous messageGo to next message
Noud,
This is why using the Update Manager is the preferred method for
installing Eclipse plug-ins... doing it manually can be complicated.
Installing Eclipse on a non-networked machine is not the usual use
case.
On 7/3/06, Noud deBrouwer <noud4@home.nl> wrote:
> Jeff Myers wrote:
> > Joe,
Links to all the Eclipse projects included in Callisto are on the
Customized install page:
http://www.eclipse.org/callisto/custom.php
GEF and
Which projects don't provide links to their requirements? You can open
enhancement requests for the projects to fix their websites here:
https://bugs.eclipse.org/bugs/enter_feature.cgi
I have no idea what you're talking about here... too many acronyms.
All eclipse projects's source are publicly available on the eclipse
cvs server. The the project metadata used by the Callisto update site
in the update manager is here:
http://download.eclipse.org/callisto/releases/site.xml
> --Noud
> > Hope this helps,
> > - Jeff
Re: Callisto install without Update Manager [message #159425 is a reply to message #159415] Mon, 03 July 2006 15:12 Go to previous messageGo to next message
Jeff Myers wrote:
> Noud,
sounds pretty valid from just the Eclipse perspective, but does not
work in conjuntion w/ various package-ing/deployment systems in use,
such as f.i. pkgsrc, ports nor (S)RPM and maybe others, f.i., you know
if SMIT will be informed?
> case.
well..having a non-networked machine is the most adviced way of having
a secure machine.. ..besides or let alone what the machine is intented
to do, let that be f.i. running/supplying Eclipse.
the first remark i made herein, strikes me the most. does.
dunno if it even came to ALF attention.
the second remark .. the non-networked-security-issue is
more a stroke i made.
--Noud
> > Jeff Myers wrote:
> > > Joe,
> GEF and
> > --Noud
> > > Hope this helps,
> > > - Jeff
Re: Callisto install without Update Manager [message #159432 is a reply to message #159425] Mon, 03 July 2006 16:10 Go to previous messageGo to next message
Noud deBrouwer wrote:
> Jeff Myers wrote:
>> Noud,
The effort to make Eclipse more easily compatible/consumable from
various Linux packaging systems is this project here:
http://wiki.eclipse.org/index.php/Linux_Distributions_Projec t
I suggest signing up with their mailing list if you'd like to
participate in the effort.
What is SMIT?
- Jeff
Re: Callisto install without Update Manager [message #159457 is a reply to message #159432] Mon, 03 July 2006 16:38 Go to previous message
>> Jeff Myers wrote:
>>> Noud,
yes allready seen.
but it's nature is different/broughter the specifics we came to namely
package and deploy.
not to over-hint, Linux Distributions Project does prefer/endorse my point,
states the same point, being it's best to start w/ the archive file and
write packageing and thus deployement around such a fornamed Eclipse
project archive.:
http://wiki.eclipse.org/index.php/Linux_Distributions_Projec t/Proposal#Issue_One_.E2.80.93_Eclipse_Installation_on_Linux
the:
http://wiki.eclipse.org/index.php/Linux_Distributions_Projec t/Proposal#Issue_Three_.E2.80.93_Linux_Integration
i find even more correct and interesting, maybe just cause there the
person(s)power/time/fund issues do play up given the differences touched
between .. say a pkgsrc and a SRPM build, power/time/fund-footprint
conserning.
this brought me to:
http://www.redhat.com/archives/fedora-devel-java-list/2005-M arch/msg00022.html
http://svn.bagu.org/pluginbuilder/
http://ftp.debian.org/debian/pool/main/c/cdbs/
for me this all initiated from the eclipsebuilder so i now have headless
build..inside pkgsrc structure.
no..i suggest, what i did, hands-on study the field a bit more.
now/then read their mailing list archive.
> What is SMIT?
IBM's software packageing and deployment manager for IBM AIX.
> - Jeff
--Noud
Previous Topic:plugin build using ant
Next Topic:French locale
Current Time: Mon Jul 21 21:24:10 EDT 2025
Powered by FUDForum. Page generated in 0.14449 seconds
