Re: New versions of DTFJ adapter and DTFJ [message #11091 is a reply to message #10782] |
Mon, 25 May 2009 15:03  |
Originally posted by: heinz.drews.gmail.com
Andrew Johnson wrote:
> osgi.bundles=org.eclipse.mat.dtfj@4:start,org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
> The reason is because the DTFJ adapter dynamically declares to MAT which
> DTFJ files it supports depending on which DTFJ implementations are
> available in the MAT application. However for this code to run the DTFJ
> adapter must get started. In GUI mode there is an extension point I can
> use to get the DTFJ adapter started. I haven't found a corresponding
> extension point in batch mode. This modification to the osgi.bundles
> statement ensures that the DTFJ adapter is started early and can then
> query the DTFJ implementation and notify MAT which files it supports.
> Once the adapter is part of the MAT distribution we might be able to do
> something better.
Thanks, the configuration change has helped.
I'm also searching for a solution getting bundles started without
changing the config.ini.
FUDForum. Page generated in 0.04741 seconds
