Re: [buckminster-dev] headless resolve with new r08988 [message #9414] |
Wed, 12 March 2008 16:07  |
Thanks Thomas, you rock the build :)
T
Thomas Hallgren
<thomas@tada.se>
Sent by: To
buckminster-dev-b Buckminster developer discussions
ounces@eclipse.or <buckminster-dev@eclipse.org>
g cc
Subject
03/12/2008 04:03 Re: [buckminster-dev] headless
PM resolve with new r08988
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
Hi Todd,
I can see where those warnings come from. The once about things starting
with # can be safely ignored (I'll remove them of course, but that's
effecively what Buckminster does anyway). I'll need to attend to the
ones with "HEAD". I'll see to that a new version is published later
tonight.
Thomas Hallgren
Todd_Lee@amis.com wrote:
> Thanks again Thomas,
> I grabbed the new product package and made my local installation, but I
> seem to get PDE errors now that seem to point to cached maps...
> C:\autobuild_root>buckminster -L INFO -data C:\autobuild_root\temp
resolve
> --bomfile C:\autobuild_root\buckminster.bom
> http://sam/ide/updates/dev/build.cquery
> WARN: Unregognized component type '#plugin' in PDE map file C:\Documents
> and Settings\leet\Local Settings\Temp\bucky49405.tmp\ant.map
> WARN: Unregognized component type '#base.plugin' in PDE map file
> C:\Documents and Settings\leet\Local
Settings\Temp\bucky49405.tmp\base.map
> WARN: No fetch factory found for id 'HEAD' in PDE map file C:\Documents
> and Settings\leet\Local Settings\Temp\bucky49405.tmp\core.map
Settings\Temp\bucky49405.tmp\equinox-incubator.map
> WARN: Unregognized component type '#feature' in PDE map file
C:\Documents
> and Settings\leet\Local Settings\Temp\bucky49405.tmp\p2.map
> and Settings\leet\Local Settings\Temp\bucky49405.tmp\releng.map
> and Settings\leet\Local Settings\Temp\bucky49405.tmp\swt.map
> ERROR [0003] : Unable to delete:
> C:\DOCUME~1\leet\LOCALS~1\Temp\bucky49405.tmp\userassist.map
> Here's the info for my local install
> C:\autobuild_root>buckminster -L DEBUG listsite
> listsite
> Features:
> org.eclipse.buckminster.core.headless.feature_1.0.0.r08990 (Buckminster
> Core Headless)
> org.eclipse.buckminster.cvs.headless.feature_1.0.0.r08989 (Buckminster
> CVS support for headless operation)
> org.eclipse.buckminster.maven.feature_1.0.0.r08939 (Buckminster - Maven
> support)
> org.eclipse.buckminster.pde.headless.feature_1.0.0.r08990 (Buckminster
> PDE support for headless operation)
> org.eclipse.buckminster.product_1.0.0.r08988 (Buckminster Product)
> Am I missing something or is it an issue with the PDE map resolver/cached
> maps?
> T
> Thomas Hallgren
> <thomas@tada.se>
> Sent by:
To
> g
cc
Subject
> 03/12/2008 01:06 Re: [buckminster-dev] headless
> PM resolve with properties
> Please respond to
> Buckminster
> developer
> discussions
> <buckminster-dev@
> eclipse.org>
> Hi Todd,
> I'll look into your problems with property settings shortly.
> The PDE map provider might have had some problems with the tags in the
> map file. That too should be fixed now though.
> A new product package and and update site has been published. You'll
> fine the latest URL's here:
> http://www.eclipse.org/buckminster/downloads.html
> Thomas Hallgren
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or
privileged. The information is intended for the use of the individual or
entity named above. If you are not the intended recipient, please be aware
that any disclosure, copying, distribution or use of the contents of this
information is prohibited. If you received this electronic message in
error, please notify the sender and delete the copy you received.
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
Re: [buckminster-dev] headless resolve with new r08988 [message #9438 is a reply to message #9414] |
Wed, 12 March 2008 19:41  |
I just deployed new stuff to our update site that should take care of your recent problems with the
eclipse.import reader. It'll be 30mins to an hour before it hits the mirrors.
I'm still not sure what causes your problems with property expansion. I'll investigate that further.
- thomas
FUDForum. Page generated in 0.03352 seconds
