Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] headless resolve with properties
Re: [buckminster-dev] headless resolve with properties [message #9340] Wed, 12 March 2008 13:16
Thanks as always Thomas!
I'll give it a try
T
Thomas Hallgren
<thomas@tada.se>
Sent by: To
buckminster-dev-b Buckminster developer discussions
ounces@eclipse.or <buckminster-dev@eclipse.org>
g cc
Subject
03/12/2008 01:06 Re: [buckminster-dev] headless
PM resolve with properties
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
Hi Todd,
I'll look into your problems with property settings shortly.
The PDE map provider might have had some problems with the tags in the
map file. That too should be fixed now though.
A new product package and and update site has been published. You'll
fine the latest URL's here:
http://www.eclipse.org/buckminster/downloads.html
Thomas Hallgren
_______________________________________________
buckminster-dev mailing list
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
AMI Semiconductor - "Silicon Solutions for the Real World"
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
Previous Topic:Re: [buckminster-dev] headless resolve with properties
Next Topic:[buckminster-dev] headless resolve with new r08988
Current Time: Sun Aug 31 15:31:22 EDT 2025
Powered by FUDForum. Page generated in 0.03649 seconds
