Home » Archived » EPP » Re: Can't get Ganymede going right? data explorer
Re: Can't get Ganymede going right? data explorer [message #8937] Wed, 11 June 2008 08:31 Go to next message
Originally posted by: codeslave.ca.ibm.com
Copying to BIRT & EPP newsgroups.
Tom Brander wrote:
> Have reinstalled Ganymede (reporting package) several times Latest
> download and install was today. To use Birt, but cannot get the data
> explorer to function with Mysql data base,, Have used the latest drivers
> (jdbc) from Mysql.. The data base pings after install and database
> configuration with driver, but no views of the data or options to
> create data source?? Error log attached.
> Help!
> I've been at this for several days now...but wanted to exhaust my
> options before posting..
> Thanks!
> !SESSION 2006-11-04 12:08:20.970
> eclipse.buildId=I20060602-1317
> java.version=1.5.0_06
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.help.base 4 0 2006-11-04 12:15:01.782
> !MESSAGE The embedded application server could not run help web
> application.
> !STACK 1
> org.eclipse.core.runtime.CoreException: Exception occurred starting
> application server.
> at
> org.eclipse.tomcat.internal.TomcatAppServer.start(TomcatAppS erver.java:271)
> at
> org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer(AppserverPlugin.java:143)
> at
> org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver(AppserverPlugin.java:41)
> at
> org.eclipse.help.internal.appserver.WebappManager.start(Weba ppManager.java:58)
> at
> org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(BaseHelpSystem.java:246)
> at
> org.eclipse.help.internal.base.HelpDisplay.displayHelpURL(He lpDisplay.java:164)
> at
> org.eclipse.help.internal.base.HelpDisplay.displayHelpResour ce(HelpDisplay.java:86)
> at
> org.eclipse.help.ui.internal.DefaultHelpUI.displayHelpResour ce(DefaultHelpUI.java:231)
> at
> org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp Resource(WorkbenchHelpSystem.java:911)
> at
> org.eclipse.ui.help.WorkbenchHelp.displayHelpResource(Workbe nchHelp.java:116)
> at
> org.eclipse.birt.report.designer.ui.actions.cheatsheets.Open HelpAction.run(OpenHelpAction.java:31)
> at
> org.eclipse.ui.internal.cheatsheets.ActionRunner.runAction(A ctionRunner.java:86)
> at
> org.eclipse.ui.internal.cheatsheets.data.Action.execute(Acti on.java:97)
> at
> org.eclipse.ui.internal.cheatsheets.views.CoreItem.runExecut able(CoreItem.java:476)
> at
> org.eclipse.ui.internal.cheatsheets.views.CoreItem.runExecut able(CoreItem.java:471)
> at
> org.eclipse.ui.internal.cheatsheets.views.CheatSheetViewer.r unPerformExecutable(CheatSheetViewer.java:991)
> at
> org.eclipse.ui.internal.cheatsheets.views.CoreItem$1.linkAct ivated(CoreItem.java:91)
> at
> org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivat e(AbstractHyperlink.java:208)
> at
> org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(I mageHyperlink.java:174)
> at
> org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp (AbstractHyperlink.java:289)
> at
> org.eclipse.ui.forms.widgets.AbstractHyperlink.access$1(Abst ractHyperlink.java:273)
> at
> org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent (AbstractHyperlink.java:110)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
> at org.eclipse.core.launcher.Main.run(Main.java:977)
> at org.eclipse.core.launcher.Main.main(Main.java:952)
> !SUBENTRY 1 org.eclipse.tomcat 4 0 2006-11-04 12:15:01.798
> !MESSAGE Exception occurred starting application server.
> !SESSION 2006-11-04 13:25:02.251
> !ENTRY org.eclipse.ui 4 4 2006-11-04 13:38:31.595
> !MESSAGE Unhandled event loop exception
> !ENTRY org.eclipse.ui 4 0 2006-11-04 13:38:31.595
> !MESSAGE Argument cannot be null
> !STACK 0
> java.lang.IllegalArgumentException: Argument cannot be null
> at org.eclipse.swt.SWT.error(SWT.java:3358)
> at org.eclipse.swt.SWT.error(SWT.java:3297)
> at org.eclipse.swt.SWT.error(SWT.java:3268)
> at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
> at org.eclipse.swt.widgets.Text.setText(Text.java:1649)
> at
> org.eclipse.birt.report.designer.data.ui.datasource.Connecti onProfileSelectionPage$3.widgetSelected(ConnectionProfileSel ectionPage.java:147)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
> at org.eclipse.jface.window.Window.open(Window.java:796)
> at
> org.eclipse.birt.report.designer.ui.actions.NewDataSourceAct ion.run(NewDataSourceAction.java:83)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
> at
> org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:229)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.ui 4 4 2006-11-04 13:41:41.626
> !ENTRY org.eclipse.ui 4 0 2006-11-04 13:41:41.626
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.ui 4 4 2006-11-04 13:46:53.751
> !ENTRY org.eclipse.ui 4 0 2006-11-04 13:46:53.751
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.birt.data 4 1001 2006-11-04 15:49:22.064
> !MESSAGE A BIRT exception occurred.
> !STACK 0
> org.eclipse.birt.data.engine.core.DataException: Cannot execute the
> statement.
> Invalid
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:567)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:482)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:330)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:735)
> at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:181)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:137)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.populateRecords(ResultSetPreviewPage.java:430)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage.access$200(ResultSetPreviewPage.java:83)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPr eviewPage$5.run(ResultSetPreviewPage.java:379)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
> Caused by: org.eclipse.datatools.connectivity.oda.OdaException: Invalid
> at
> org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.splitStringWithDoubleQuotes(FlatFileQuery.java:936)
> at
> org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQueriedDataFromRow(FlatFileQuery.java:850)
> at
> org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.fetchQueriedDataFromFileToVector(FlatFileQuery.java:822)
> at
> org.eclipse.datatools.connectivity.oda.flatfile.FlatFileQuer y.executeQuery(FlatFileQuery.java:161)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doExecuteQuery(OdaQuery.java:443)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.executeQuery(OdaQuery.java:408)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.e xecute(PreparedStatement.java:553)
> ... 9 more
> !SUBENTRY 1 org.eclipse.birt.data 1 1001 2006-11-04 15:49:22.064
> !MESSAGE Plug-in Provider:Eclipse.org
> !MESSAGE Plug-in Name:BIRT Data Engine
> !MESSAGE Plug-in ID:org.eclipse.birt.data
> !MESSAGE Version:2.1.1.v20060922-1058
> !SUBENTRY 1 org.eclipse.birt.data 4 1001 2006-11-04 15:49:22.064
> !MESSAGE Error Code:odaconsumer.CannotExecuteStatement
> !MESSAGE Error Message:Cannot execute the statement.
> Invalid
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Can't get Ganymede going right? data explorer [message #8958 is a reply to message #8937] Wed, 11 June 2008 08:48 Go to previous messageGo to next message
Thanks for the follow-up. Found the Birt group but what is EPP?
Tom
Re: Can't get Ganymede going right? data explorer [message #8979 is a reply to message #8958] Wed, 11 June 2008 09:04 Go to previous messageGo to next message
EPP == Eclipse Packaging Project
http://www.eclipse.org/epp/
This is the project responsible for building the Europa and Ganymede
bundles.
> Tom
Re: Can't get Ganymede going right? data explorer [message #8996 is a reply to message #8958] Wed, 11 June 2008 09:34 Go to previous message
> Tom
Maybe you should open a bug against this package.
Go back to the page where you downloaded the reporting package
(http://www.eclipse.org/downloads/packages/), click on the 'More...' link
of the 'Eclipse IDE for Java and Report Developers' package. On the
following page, you'll find a link 'File a Bug on this Package' on the
bottom right.
This will help the BIRT team by reproducing and fixing this bug.
Markus
Re: Can't get Ganymede going right? data explorer [message #577264 is a reply to message #8937] Wed, 11 June 2008 08:48 Go to previous message
Tom
Re: Can't get Ganymede going right? data explorer [message #577289 is a reply to message #8958] Wed, 11 June 2008 09:04 Go to previous message
bundles.
> Tom
Re: Can't get Ganymede going right? data explorer [message #577311 is a reply to message #8958] Wed, 11 June 2008 09:34 Go to previous message
> Tom
bottom right.
Markus
Previous Topic:Re: Can't get Ganymede going right? data explorer
Next Topic:UDC in own RCP applications
Current Time: Sat Aug 30 21:47:05 EDT 2025
Powered by FUDForum. Page generated in 0.15923 seconds
