Home » Archived » EPF » EPF on Jazz
EPF on Jazz [message #47562] Thu, 31 January 2008 06:01 Go to next message
I am trying to get single eclipse for Jazz 0.6Beta2 + EPF 1.2.0.2
I have done:
1/ Added all required plugins and versions in Jazz eclipse (GEF, GMF, EMF
SDK, etc.) as extensions
2/ Created EPF 1.2.0.2 Extension (removed all Eclipse, GEF, etc. plugins,
epf plugins just left)
3/ Install manager looks OK without any errors in any extension
When I started Jazz eclipse I saw EPF perspectives added (Authorization,
Browsing); however, if I open library I get following error for every node
(plugin):
!ENTRY org.eclipse.jface 4 2 2008-01-30 20:19:42.564
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.emf.common.EMFPlugin$InternalHelper.getString(EM FPlugin.java:725)
org.eclipse.emf.common.EMFPlugin$EclipsePlugin.getString(EMF Plugin.java:621)
at org.eclipse.emf.common.EMFPlugin.getString(EMFPlugin.java:45 0)
org.eclipse.emf.edit.provider.ItemProviderAdapter.getString( ItemProviderAdapter.java:1808)
org.eclipse.emf.edit.provider.ItemProviderAdapter.getString( ItemProviderAdapter.java:1800)
org.eclipse.epf.library.edit.element.ContentPackageItemProvi der.getText(Unknown
Source)
org.eclipse.emf.edit.ui.provider.AdapterFactoryLabelProvider .getText(AdapterFactoryLabelProvider.java:199)
org.eclipse.jface.viewers.DecoratingLabelProvider.getText(De coratingLabelProvider.java:129)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:351)
org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:183)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:135)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:911)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:97)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:991)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2026)
org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:806)
org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:781)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:755)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:627)
org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1410)
org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:918)
org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1421)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:125)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7053)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1541)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5798)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3705 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5370)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Any ideas?
Roman
Re: EPF on Jazz [message #47595 is a reply to message #47562] Thu, 31 January 2008 11:43 Go to previous messageGo to next message
Originally posted by: phaumer.us.no-spam.ibm.com
Hello Roman.
I forward this to Shilpa to look at the exception as well, but here is how I
did the shell sharing integration with RMC 7.2 ifix2 (which is based on EPFC
1202) without any issues:
- unzip the jazz beta2a client distribution in <install_dir>
- in the <install_dir>\jazz\client\eclipse directory create a directory
called "epfc" with a sub-directory "eclipse"
- drag and drop the "features" and "plugins" directories from the EPFC
distribution into <install_dir>\jazz\client\eclipse\epfc\eclipse\
- go to <install_dir>\jazz\client\eclipse\links and create a file called
epfc.lnk that contains this one line "path=epfc"
Start the "<install_dir>\jazz\client\TeamConcert.exe", create a fresh new
workspace and send us the <workspace>\.metadata\.log file
If you find in there just a few bundle warnings and handler conflicts then
everything should work as it does for our team who also uses this
integration for our content development work.
Peter.
"Roman Smirak" <roman.smirak@tietoenator.com> wrote in message
news:fns9pn$u1c$1@build.eclipse.org...
> I have done:
> (plugin):
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any ideas?
> Roman
Re: EPF on Jazz [message #47625 is a reply to message #47595] Thu, 31 January 2008 13:57 Go to previous messageGo to next message
Hi Peter,
thanks, your way works for me as well; I don't see why the previous one
failed (my intent was to avoid the duplicity)... Anyway, I'm attaching the
..log file.
Roman
"Peter Haumer" <phaumer@us.no-spam.ibm.com> wrote in message
news:fnstqi$pd5$1@build.eclipse.org...
> Hello Roman.
> I
> EPFC
> Peter.
>> I have done:
>> node
>> (plugin):
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Any ideas?
>> Roman
  • Attachment: .log
    (Size: 15.88KB, Downloaded 287 times)
Re: EPF on Jazz [message #47655 is a reply to message #47595] Thu, 31 January 2008 14:00 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
If you do shell-share integration like Peter mentioned, it should work. It
worked for me fine.
Did you get complete set of "emf" plugins ? Jazz didn't have complete set
of "emf" plugins which EPF composer needed at least in earlier version of
jazz. That may be cause of the exception. I haven't checked latest jazz
version, so can't say for sure.
Shilpa
Re: EPF on Jazz [message #47685 is a reply to message #47655] Thu, 31 January 2008 14:08 Go to previous message
You are right, Jazz doesn't include all of them (1.0Beta2) - and so I added
EMF SDK 2.3.0 (I followed
http://www.eclipse.org/epf/composer_dev_guide/dev_env.php)
Roman
"Shilpa Toraskar" <storaskar@xx.xxx.xxx> wrote in message
news:40ed3bd19ecfbf06537ee915322daa79$1@www.eclipse.org...
> worked for me fine.
> Shilpa
Re: EPF on Jazz [message #588306 is a reply to message #47562] Thu, 31 January 2008 11:43 Go to previous message
Hello Roman.
Peter.
> I have done:
> (plugin):
> !STACK 0
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any ideas?
> Roman
Re: EPF on Jazz [message #588316 is a reply to message #47595] Thu, 31 January 2008 13:57 Go to previous message
Hi Peter,
..log file.
Roman
> Hello Roman.
> I
> EPFC
> Peter.
>> I have done:
>> node
>> (plugin):
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Any ideas?
>> Roman
  • Attachment: .log
    (Size: 15.88KB, Downloaded 198 times)
Re: EPF on Jazz [message #588329 is a reply to message #47595] Thu, 31 January 2008 14:00 Go to previous message
worked for me fine.
Shilpa
Re: EPF on Jazz [message #588335 is a reply to message #47655] Thu, 31 January 2008 14:08 Go to previous message
Roman
> worked for me fine.
> Shilpa
Previous Topic:EPF on Jazz
Next Topic:WAR - Search - Weblogic 10
Current Time: Tue Jul 22 21:21:44 EDT 2025
Powered by FUDForum. Page generated in 0.08550 seconds
