Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » refactoring sources - please let us know
refactoring sources - please let us know [message #33632] Thu, 23 October 2008 19:04 Go to next message
I appreciate the fact that you guys have developed DLTK and made it open
source so we can use it.
I appreciate the fact that you respond to this forum so we know how to use
it.
I was told that I should:
a) be using the latest 1.0 source tree that you are actively developing
b) use IBuildParticipant and the associated extension point
Unfortunately, that does not exist in the stable 1.0M2 release - only in the
latest integration build.
Thus, I have just upgraded to the integration build.
In the process - I have discovered many other changes:
1) The IBuildParticipant interface has changed to use IBuildContext instead
2) A while ago - you told me that your AST node would not be updated to
track line numbers - even though they are available at parse time - and that
we should use a line tracker. So, I wrote some code o create and use line
trackers (Eclipse's ILineTracker). Unfortunately, all of that code is moot
now that you have your own DLTK ISourceLineTracker.
So, what I'm asking, is that if you make incompatible changes, please
announce them so we can be prepared for them when you make the next release
available.
Chuck
Re: refactoring sources - please let us know [message #33735 is a reply to message #33632] Fri, 24 October 2008 03:19 Go to previous messageGo to next message
Hi Chuck,
Sometimes we have to make incompatible changes if they are required to
implement new features.
Historically the changes are announced on the dltk-dev@eclipse.org
mailing list. I would recommend you to subscribe to it. The link to
subscribe is available on the http://www.eclipse.org/dltk/
site.
These changes were announced on the mailing list and I have posted the
link to the message in the "parsers, builders, build types, and build
participants" news thread. Here is that link again
http://dev.eclipse.org/mhonarc/lists/dltk-dev/msg01142.html
> it.
It depends on the parser if line numbers are provided from it.
Some parsers are just operating on the char arrays and they don't need
to track line boundaries/numbers. The essential information is just the
offset in the source.
We think that some languages could benefit from the standard
implementation provided by the DLTK. Unfortunately the mentioned
ILineTracker is provided by the org.eclipse.jface.text plugin and we
don't want dltk.core to depend on that plugin, so we have to provide own
interface for the same task.
> available.
We try to announce changes, it is just happens in different place - on
the mailing list. Also, most of the technical discussions happens there too.
Alex
Re: refactoring sources - please let us know [message #33769 is a reply to message #33735] Fri, 24 October 2008 10:41 Go to previous messageGo to next message
Ok - I have subscribed to the dev mailing list.
Thanks for the suggestion.
Chuck
"Alex Panchenko" <alex@xored.com> wrote in message
news:gdrstm$l1n$1@build.eclipse.org...
> Hi Chuck,
> Historically the changes are announced on the dltk-dev@eclipse.org mailing
> list. I would recommend you to subscribe to it. The link to subscribe is
> site.
>> use it.
>> the latest integration build.
>> instead
>> that we should use a line tracker.
> Some parsers are just operating on the char arrays and they don't need to
>> So, I wrote some code o create and use line trackers (Eclipse's
>> ILineTracker). Unfortunately, all of that code is moot now that you have
> ILineTracker is provided by the org.eclipse.jface.text plugin and we don't
>> release available.
> We try to announce changes, it is just happens in different place - on the
> Alex
Re: refactoring sources - please let us know [message #33803 is a reply to message #33632] Fri, 24 October 2008 16:42 Go to previous message
> available.
Maybe DLTK should adopt PDE API Tools?
http://www.google.com/url?sa=U&start=4&q=http://www. ibm.com/developerworks/opensource/library/os-eclipse-api-too ls/
That way, you can tell if you're breaking API. As an Eclipse project,
you shouldn't be breaking API in point releases.
http://www.google.com/url?sa=U&start=3&q=http://wiki .eclipse.org/Version_Numbering
Let me know if you have any questions.
I know it's hard to stablize on an API :)
~ Chris
Previous Topic:problemreporter bug in 0.95.1 released version
Next Topic:[BUILD] R1.0-I
Current Time: Wed Jul 16 23:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.29280 seconds
