Home » Eclipse Projects » Eclipse Platform » How to link multipage editor to source code file?
How to link multipage editor to source code file? [message #329143] Fri, 13 June 2008 13:15 Go to next message
Originally posted by: tchurch+eclipse.nullring.com
[Reposting from eclipse.newcomer group since this is forms related]
I am trying to develop a simple multipage editor that has 2 pages. The
first page is an eclipse form with a couple input fields, and the second
page is the source xml file. I am able to create both pages, but I am
missing a fundamental concept - how do I link the form page to the source
xml file? In other words, how can I have the input on the form page
automatically update the related field in the xml file when it is edited?
Does anyone have a simple example of how this works?
I have searched through the newsgroup and read through the help, but this
has not been clear to me. I have tried to trace through the code for the
Plugin Manifest Editor but have been unable to follow it.
My assumption is that I need some sort of listener on the input field,
probably a ModifyListener, which will open the xml file, parse it for the
correct field, update the field, and then refresh the source page. Is
this the correct approach?
Re: How to link multipage editor to source code file? [message #329163 is a reply to message #329143] Mon, 16 June 2008 05:36 Go to previous messageGo to next message
> source xml file? In other words, how can I have the input on the form
> page automatically update the related field in the xml file when it is
> edited?
> this has not been clear to me. I have tried to trace through the code
> for the Plugin Manifest Editor but have been unable to follow it.
> the correct field, update the field, and then refresh the source page.
> Is this the correct approach?
hi, tim, you can analyze the source code of WST XML editor , which is a
two-page editor.
1 Record the line nubmer of every xml element when resolving XML file.
2 Every UI widget you constructed need contain a property whose value is
line number for according xml element.
you can do it like this :
widget.setData("StartLineNumber",elementLineMap.get(element));
Re: How to link multipage editor to source code file? [message #329228 is a reply to message #329163] Mon, 16 June 2008 17:59 Go to previous messageGo to next message
I do not have the source code for the WST XML editor. I am using the
Eclipse for RCP/Plug-in Developers (Europa) version. Can this be
downloaded somewhere?
Re: How to link multipage editor to source code file? [message #329263 is a reply to message #329228] Tue, 17 June 2008 13:33 Go to previous message
For anyone who is missing source code, I found instructions on how to
check out the source from the CVS repository to add it to your local
Eclipse -
http://www.eclipse.org/webtools/community/tutorials/Developi ngWTP/DevelopingWTP.html
Previous Topic:Migration Questions
Next Topic:special Jface dialog
Current Time: Sat Jul 26 00:55:27 EDT 2025
Powered by FUDForum. Page generated in 0.04432 seconds
