A BIRT exception occurred [message #938169] |
Tue, 09 October 2012 16:11 |
Ernest F Messages: 2 Registered: October 2012 |
Junior Member |
When trying to run a report in Eclipse using the fully-qualified hostname of a server, the following error occurs. I've blocked out the hostname for security purposes.
A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: Wrapped com.ibm.tivoli.maximo.report.script.MXReportRuntimeException: com.microsoft.sqlserver.jdbc.SQLServerException: The TCP/IP connection to the host XXXXX.local.com, port 1433 has failed. Error: "connect timed out. Verify the connection properties, check that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port, and that no firewall is blocking TCP connections to the port.". (/report/data-sets/script-data-set[@id="5"]/method[@name="open"]#2)
Script source: /report/data-sets/script-data-set[@id="5"]/method[@name="open"], line: 0, text:
__bm_OPEN(). (Element ID:1)
When using only XXXXX (removing the .local.com), or an IP address, the report runs without any issues.
The fully-qualified hostname can be pinged with successful responses.
Any idea what might cause this?
FUDForum. Page generated in 0.03242 seconds
