Home » Eclipse Projects » BIRT » Birt PDF Report: Ordered List Style Type Issue(Unable to change style type to Upper/Lower alpha in Ordered List in PDF report)
Birt PDF Report: Ordered List Style Type Issue [message #937469] Mon, 08 October 2012 21:53 Go to next message
Prabhat Kumar is currently offline Prabhat Kumar
Dear All,
I am generating PDF report using BIRT 2.5.3. I have passed HTML content type and want to generate Ordered list using style type as Upper Alpha i.e as A, B, C etc. . I mean, i want to generate like below ordered list:
A. This is Line 1
B. This is Line 2
C. This is Line 3
But every time i get the PDF report with number 1, 2, 3 but not with A, B, C as below:
1. This is Line 1
2. This is Line 2
3. This is Line 3
I have used below HTML code for this:
<ol style="list-style-type: upper-alpha;"><li>This is Line 1</li><li>This is Line 2</li><li>This is Line 3</li></ol>
Apparently, it is working fine when i generate in HTML (rendering option as HTML) but not with PDF (rendering option PDF).
Hope, the above information will be helpful to understand the problem.
Thanks in advance.
Prabhat Kumar
Re: Birt PDF Report: Ordered List Style Type Issue [message #938282 is a reply to message #937469] Tue, 09 October 2012 14:35 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
I do not think this is currently supported in the pdf emitter. Can you open a bugzilla for this?
Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Change report title property value at runtime
Next Topic:Passing sub report totals to expressions
Current Time: Wed May 22 17:33:14 EDT 2013
Powered by FUDForum. Page generated in 0.01467 seconds
