Installation Help - Two Plug-ins? [message #572189] |
Sun, 15 March 2009 17:38 |
Ray Joseph Messages: 87 Registered: July 2009 |
Member |
I am having difficulties installing OSEE.
I have Version: 3.4.1, Build id: M20080911-1700, on a Windows 2000 SP4
box, with Java Version 1.6.0_11 from Sun Microsystems Inc.
Starting from:
http://www.eclipse.org/osee/documentation/installation/eclip se_install.php
I do the following:
Download org.ecilpse.osee_integration_build_incubation.zip.
and get org.ecilpse.osee_integration_build_incubation.zip which is 38 MB.
The install says I need the dependencies:
eclipse-reporting-ganymede-SR2-win32.zip
which downloads: eclipse-reporting-ganymede-SR2-win32.zip which is 200
MB.
I then add both of these new local folders for installation and then
select install. I get a message:
The software items you selected may not b e valid with your current
installation. Do you want to open the wizard anyway to review the
selections?
Continuing, I get:
Install Window
Cannot complete the request. See the details.
Eclipse CVS Client is already installed, so an update will be performed
instead.
Eclipse Help System is already installed, so an update will be performed
instead.
Eclipse Java Development Tools is already installed, so an update will be
performed instead.
Eclipse Platform is already installed, so an update will be performed
instead.
Eclipse RCP is already installed, so an update will be performed instead.
Eclipse XML Editors and Tools is already installed, so an update will be
performed instead.
EMF - Eclipse Modeling Framework Core Runtime is already installed, so an
. . and much more which end in:
Unsatisfied dependency: requiredCapability:
osgi.bundle/org.eclipse.wst.common.project.facet.core/[1.2.1 ,1.3.0)
Unsatisfied dependency: [org.eclipse.wst.common.project.facet.ui
1.2.1.v200708232226] requiredCapability:
Not on the install page, but on the download page, there is an instruction:
When launching the client you must set the following java system
properties (i.e. include them in the command used to launch eclipse)
-Dosee.authentication.protocol=trustAll
-Dosee.arbitration.server=http://localhost:8089
I don't know how to do this.
I want to use PostgreSQL but I can't tell if I need anything installed
before the OSEE or after.
Since I already of Eclipse installed with some other components, I don't
want to download the all in one and overwrite what I have.
I would appreciate any suggestions on how to perform the installation.
Ray
FUDForum. Page generated in 0.03103 seconds
