Home » Language IDEs » ServerTools (WTP) » Serve modules without publishing causing classpath issue
Serve modules without publishing causing classpath issue [message #214794] Tue, 03 June 2008 16:16 Go to previous message
Originally posted by: jon.barnard.s1.com
I'm trying to run a dynamic web project in Server modules without
publishing mode. The web project has several jar libraries and several
utility projects. One of the utility projects is overwriting a class
definition in one of the jar files. The overwrite works just fine when I
publish the utility projects as a jar.
I did some deep debugging and I see that utility projects are at the end
of the classpath. Is there any way to configure this?
Read Message
Read Message
Read Message
Previous Topic:Key binding in a multi page editor
Next Topic:Deploying project dependencies
Current Time: Mon Oct 13 01:22:31 EDT 2025
Powered by FUDForum. Page generated in 0.04141 seconds
