Home » Eclipse Projects » DSDP - Target Management » Re: Publishing in new PDT?
Re: Publishing in new PDT? [message #30709] |
Sat, 10 January 2009 23:53 |
Originally posted by: dcarver.starstandard.org
I've added the Target Management newsgroup to this thread. They should
be able to answer this question, and any issues with RSE and
synchronization.
Dave
sNop wrote:
> Piernik napsal(a):
>> If You get answer can You post it here??
> of course man, but i have problem with RSE, i have tried rse few mounths ago and the same
> problem now.
> I can't fetch dir, or 1 from 10 fetching hangs with timeout, so import project with 5000
> and many folders is impossible for me
> I wan to ask you if you have the same problem with rse
> thank you for reactions
Re: Publishing in new PDT? [message #30814 is a reply to message #30709] |
Mon, 12 January 2009 13:13 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hi sNOP,
could we have a bit more information? Like what connection type you use
(I assume ssh)? There are known issues with the way that openSSH
implements some queries, which can lead to "out of handles" errors
on the server.
We're planning to improve the SSH connector for RSE 3.1m5 in terms
of performance, and I think that this improvement should also address
the mentioned openSSH problem:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256581
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> synchronization.
> Dave
> sNop wrote:
>> Piernik napsal(a):
>> problem now.
>> project with 5000
Re: Publishing in new PDT? [message #30849 is a reply to message #30814] |
Mon, 12 January 2009 14:12 |
I believe the issue is occurring for sNop with an FTP connection.
Dave
Martin Oberhuber wrote:
> Hi sNOP,
> on the server.
> Cheers,
>> should be able to answer this question, and any issues with RSE and
>> synchronization.
>> Dave
>> sNop wrote:
>>> Piernik napsal(a):
>>> problem now.
Re: Publishing in new PDT? [message #30988 is a reply to message #30953] |
Tue, 13 January 2009 00:35 |
sNop: you might want to open this as a bug/enhancement request for RSE
in the dsdp.tm project. That way it doesn't get lost in the newsgroup.
Dave
sNop wrote:
> Martin Oberhuber napsal(a):
>> Hi sNOP,
>> on the server.
> I have created video, where it's all described.
> On the other site is Unix ProFtp in first example and Linux ProFtp 1.3.1 in second example.
> In this video you can see, that RSE is for me unusable. You could see every thing in this
> video.
> I hope and i would be very very happy, if this prbolem would be ficex in next version.
> http://rapidshare.com/files/182614377/rse-fetch-problems.7z
Re: Publishing in new PDT? [message #578425 is a reply to message #30709] |
Hi sNOP,
on the server.
> synchronization.
> Dave
> sNop wrote:
>> Piernik napsal(a):
>> problem now.
>> project with 5000
Re: Publishing in new PDT? [message #578448 is a reply to message #30814] |
Dave
> Hi sNOP,
> on the server.
> Cheers,
>> synchronization.
>> Dave
>> sNop wrote:
>>> Piernik napsal(a):
>>> problem now.
Re: Publishing in new PDT? [message #578532 is a reply to message #30953] |
Dave
>> Hi sNOP,
>> on the server.
> video.
Current Time: Fri Apr 26 21:26:58 GMT 2024
Powered by FUDForum. Page generated in 0.04088 seconds
