PageBook and TreeViewer [message #305021] |
Wed, 21 June 2006 15:28 |
Originally posted by: automatic.javalobby.org
Hello!Im working on a RCP application and in one of my views, I have to display informations in a TreeViewer depending on which editor is activated.So I thought about using a PageBook.But I have a problem: it seems that I have some display issues with the PageBook: each time I activate a new editor, I create a new TreeViewer corresponding to it and I try to display it: _pageBook.showPage(_treeViewer.getControl()); For the first tree viewer, it works well, but when I try to display another one, my PageBook displays nothing, or the same TreeViewer has before but with no response to any mouse click
And when I come back to the first editor, the tree viewer corresponding to it is still well displayed
I dont understand what is happening
So, basically, it seems to work but only with the first displayed TreeViewer!!Could somebody please help me?Thanks by advance!C.B.
Re: PageBook and TreeViewer [message #305121 is a reply to message #305021] |
Fri, 23 June 2006 08:57 |
Well, I didn't succed in using the Eclipse API PageBook... :-/
So I did it another way: I use only one TreeViewer and I reload it with the current data when the editor is changed.
I store the expanded elements in a HashMap<String,Object[]> where teh keys are the name of the current project (one tree structure per project) and the values are the expanded elements, and I save everything in a memento when I quit the view...
It seems to be working!
Re: PageBook and TreeViewer [message #305123 is a reply to message #305021] |
Fri, 23 June 2006 08:58 |
Well, I didn't succeed in using the Eclipse API PageBook... :-/
Re: PageBook and TreeViewer [message #305194 is a reply to message #305188] |
Mon, 26 June 2006 08:52 |
I thought about that, but the problem is that every view (including the one I'm currently interested in) in the applicatiion extend an amount of abstract classes and I would have had to break a little bit the architecture which is not mine, create top interfaces, duplicate a lot of code, and so on...Too bad the Java does not support multiple inheritance for those type of issues :-/...Anyway, the solution I found seems to be working ;-)!
FUDForum. Page generated in 0.59555 seconds
