Home » Eclipse Projects » Eclipse Platform » Display a status file in a console-like view: SWT.ERROR_THREAD_INVALID_ACCESS
Display a status file in a console-like view: SWT.ERROR_THREAD_INVALID_ACCESS [message #304641] Tue, 13 June 2006 08:19 Go to next message
Originally posted by: wolfgang.moestl.softwareag.com
Hi All,
What would bet the recommended way to watch for changes in a file and
print the new lines to the console view?
I’m writing a Plugin for an external program, which writes its progress
and status information to files. The external program can run for quite a
while.
Every time one of the status files is updated I want the new line(s) to be
displayed either in the console or in a self-written console-like view.
Currently I’m checking the status file using a separated thread reading
the file and updating the model of the self-written console-style view.
Unfortunately this seems not to be possible, because SWT throws a
SWT.ERROR_THREAD_INVALID_ACCESS exception in the
org.eclipse.swt.widgets.Widget checkWidget () method because my file
listening thread is causing a redraw in order to tell the widget to
display the updated model:
8<=============================================
if (display.thread != Thread.currentThread ()) error
(SWT.ERROR_THREAD_INVALID_ACCESS);
==============================================>8
So this approach does not look promising.
Do I miss something here or is there a better way to display the status
file information?
Thanks a lot!
Wolf
Re: Display a status file in a console-like view: SWT.ERROR_THREAD_INVALID_ACCESS [message #304642 is a reply to message #304641] Tue, 13 June 2006 08:30 Go to previous message
Yes you need to run your code which updates any SWT-Widget in
Display.syncExec( new Runnable() );-block
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet7.j ava
Tom
Wolfgang schrieb:
> Hi All,
> I�m writing a Plugin for an external program, which writes its progress
> a while.
> be displayed either in the console or in a self-written console-like view.
> Currently I�m checking the status file using a separated thread reading
> file information?
> Thanks a lot!
> Best regards,
> Wolf
Previous Topic:Setting baseTOCS doesn't change TOC order
Next Topic:First column in TableViewer displaying problem in eclipse3.0.2
Current Time: Wed Nov 05 12:28:32 EST 2025
Powered by FUDForum. Page generated in 0.03070 seconds
