Home » Eclipse Projects » Eclipse Platform » TextViewer and positioning it in the dialog
| TextViewer and positioning it in the dialog [message #304617] |
Mon, 12 June 2006 18:44  |
I'm trying to set the position of TextViewer in the dialog
which has a GridLayout set.
protected Control createDialogArea(Composite parent)
Composite composite = new Composite(parent, SWT.NONE);
GridLayout layout = new GridLayout(1, false);
composite.setLayout(layout);
Label codeLabel = new Label(composite, SWT.NONE);
codeLabel.setText("&Label:");
codeLabel.setLayoutData(new GridData(GridData.BEGINNING,
GridData.BEGINNING, false, false));
codeTextViewer = new TextViewer(getShell(), SWT.MULTI);
codeTextViewer.getControl().setLayoutData(new GridData(450, 100));
codeTextViewer.setInput(new Document());
I also have this method:
protected void createButtonsForButtonBar(Composite parent)
createButton(parent, IDialogConstants.OK_ID,
IDialogConstants.OK_LABEL, true);
createButton(parent, IDialogConstants.CANCEL_ID,
IDialogConstants.CANCEL_LABEL, false);
The trouble is that TextViewer is always set on the bottom end of the
dialog - under the OK, CANCEL buttons! Label 'codeLabel' sits over
the buttons...
I've tried to move the code of the TextViewer around the
createDialogArea method but it had no effect.
It has expected dimensions, but the position is wrong.
Thanks for your replies.
Piotr Gorny
| Re: TextViewer and positioning it in the dialog [message #304629 is a reply to message #304617] |
Tue, 13 June 2006 03:35   |
Piotr Gorny schrieb:
codeTextViewer = new TextViewer(composite, SWT.MULTI);
Tom
| Re: TextViewer and positioning it in the dialog [message #304630 is a reply to message #304629] |
Tue, 13 June 2006 04:22   |
> Tom
Hello again Tom :-)
I'm afraid I've tried this solution earlier.
That's not the clue. I've left the composite and set getShell()
because the first one didn't work.
Piotr Gorny
| Re: TextViewer and positioning it in the dialog [message #304633 is a reply to message #304630] |
Tue, 13 June 2006 06:37   |
>>> Hi,
>> Tom
> Hello again Tom :-)
> Piotr Gorny
This code works perfectly for me on Eclipse-3.2 RC6.
---------------8<---------------
public static void main (String [] args) {
Display display = new Display ();
Shell shell = new Shell (display);
shell.setLayout(new FillLayout());
Dialog dia = new Dialog(shell) {
protected Control createDialogArea(Composite parent) {
Composite composite = (Composite)super.createDialogArea(parent);
GridData(GridData.BEGINNING,GridData.BEGINNING, false, false));
TextViewer codeTextViewer = new TextViewer(composite, SWT.MULTI);
return composite;
dia.open();
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
| Re: TextViewer and positioning it in the dialog [message #304638 is a reply to message #304635] |
Tue, 13 June 2006 07:03  |
> thanks to your snippet I've found the reason:
> I had:
> //Composite composite = new Composite(parent, SWT.NONE);
> ..but should have:
> Composite composite = (Composite) super.createDialogArea(parent);
> Unfortunately i don't understand why should I use the latter version :-(
Well if I replace the super call with the lines below i get the same
result as I got when calling super.
Composite composite = new Composite(parent,SWT.NONE);
composite.setLayout(new GridLayout(1,false));
Tom
Current Time: Wed Nov 05 12:28:31 EST 2025
Powered by FUDForum. Page generated in 0.04857 seconds
