Re: Component Diagrams with ball & socket in UI [message #1619057 is a reply to message #1615863] |
Mon, 16 February 2015 09:59 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Manoj,
Quote:Thanks very much for quick reply. Is there any way to enable (at my own risk) as my client is mandatating this ui.
I don't think so; unless you use an older version of Papyrus in which it was "supported" (Papyrus 0.10.x/Kepler). But then you'd lose support for many other things available in 1.0.x/Luna (Including performances & stability)
In Papyrus/Mars, you can "cheat" a little bit by changing the appearance of a Node (Using an SVG image to replace the default figure). But that is also a limited workaround (Especially for the Socket notation, which would need to be rotated to be visualized properly; and you can't do that yet). Moreover, Papyrus/Mars isn't released yet, so I wouldn't recommend this option either
Camille
Camille Letavernier
FUDForum. Page generated in 0.04770 seconds
