Home » Eclipse Projects » Eclipse Platform » Common Navigator Framework - needs samples
Common Navigator Framework - needs samples [message #303688] |
Fri, 19 May 2006 07:15 |
Originally posted by: lars.nospam.org
Hi forum,
I attended the Common Navigator Framework session at EclipseCon2006 and was
impressed.
What I really would like is some good samples, or is the best way to dig
into the source for WTP, DSP and CDT?
BR
Lars
Re: Common Navigator Framework - needs samples [message #303722 is a reply to message #303706] |
Fri, 19 May 2006 21:38 |
Hi Michael,
When I came back home from EclipseCon I was eager (you did a good
presentation) to throw away our "home-made" navigator
and replace it with the CommonNavigator approach solution. But not with
sucess....
W have some really basic things that I want to achive:
- Only show projects that has our specific nature
- Filter out all files with a leading dot (e.g. .project)
- Supply new, delete and all common resource activites
- Be VCS aware (e.g. ClearCase)
Is this something that is feasable for the CommonNavigator framework with
little or much coding?
BR
Lars
"Michael D. Elder" <mdelder@us.ibm.com> skrev i meddelandet
news:e4kjt0$cqa$1@utils.eclipse.org...
> Hi LO,
> At this point, the best samples are the Resource extension
> (org.eclipse.ui.navigator.resources) and the Test extension
> (org.eclipse.ui.tests.navigator) both available in the Eclipse platform
> CVS repo. There has been much interest in more formal, documented samples
> so I'll be working on that and hope to have something out in a few weeks.
> -MDE.
> LO wrote:
>> Hi forum,
>> was impressed.
>> BR
>> Lars
Re: Common Navigator Framework - needs samples [message #303731 is a reply to message #303722] |
Sat, 20 May 2006 21:44 |
Michael D. Elder Messages: 62 Registered: July 2009 |
Member |
Hi LO,
Try
http://scribbledideas.blogspot.com/2006/05/building-common-n avigator-based-viewer.html
. You can take care of the first three items with no coding at all.
The last one will depend on your repository provider. If they define
Object Contributions for IResource elements, you should be fine.
Otherwise, you may need to define an extension (either
org.eclipse.ui.popupMenus or
org.eclipse.ui.navigator.navigatorContent:actionProvider) to add those
menu options. Assuming you already have the actions, this shouldn't be
difficult.
-MDE.
LO wrote:
> Hi Michael,
> sucess....
> BR
> Lars
>> Hi LO,
>> -MDE.
>> LO wrote:
>>> Hi forum,
>>> was impressed.
>>> BR
>>> Lars
Re: Common Navigator Framework - needs samples [message #303800 is a reply to message #303731] |
Tue, 23 May 2006 15:30 |
Hi Michael,
Your blogg entry about common navigator (specially part II) was exactly what
I needed.
Thanx!
/Lars
news:e4o2jo$tkc$1@utils.eclipse.org...
> Hi LO,
> Try
> http://scribbledideas.blogspot.com/2006/05/building-common-n avigator-based-viewer.html .
> You can take care of the first three items with no coding at all. The last
> one will depend on your repository provider. If they define Object
> Contributions for IResource elements, you should be fine. Otherwise, you
> may need to define an extension (either org.eclipse.ui.popupMenus or
> difficult.
> -MDE.
> LO wrote:
>> Hi Michael,
>> sucess....
>> BR
>> Lars
>>> Hi LO,
>>> samples so I'll be working on that and hope to have something out in a
>>> few weeks.
>>> -MDE.
>>> LO wrote:
>>>> Hi forum,
>>>> was impressed.
>>>> dig into the source for WTP, DSP and CDT?
>>>> BR
>>>> Lars
Re: Common Navigator Framework - needs samples [message #304014 is a reply to message #303800] |
Sun, 28 May 2006 22:04 |
Member |
I've posted a request for feedback from the community to prioritize
upcoming examples. Please respond to the blog at
http://scribbledideas.blogspot.com/ .
-MDE.
LO wrote:
> Hi Michael,
> I needed.
> Thanx!
> /Lars
>> Hi LO,
>> Try
>> difficult.
>> -MDE.
>> LO wrote:
>>> Hi Michael,
>>> sucess....
>>> BR
>>> Lars
>>>> Hi LO,
>>>> few weeks.
>>>> -MDE.
>>>> LO wrote:
>>>>> Hi forum,
>>>>> was impressed.
>>>>> BR
>>>>> Lars
Current Time: Fri Apr 26 10:05:55 GMT 2024
Powered by FUDForum. Page generated in 0.03905 seconds
