Home » Eclipse Projects » Eclipse Platform » common navigator examples empty ? EclipseCon ?
common navigator examples empty ? EclipseCon ? [message #303173] Wed, 10 May 2006 05:22 Go to next message
Lookin at eclipse cvs to try and find the src of the example used in the
EclipseCon talk about
common navigator I found /org.eclipse.ui.examples.navigator but it is
empty :(
Anyone know where the EclipseCon src can be found ? (I could only find the
presentation file)
/max
Re: common navigator examples empty ? EclipseCon ? [message #303453 is a reply to message #303173] Mon, 15 May 2006 22:01 Go to previous messageGo to next message
Hi Max,
The example used is derived from the test extension in
org.eclipse.ui.tests.navigator. This is your best bet, as it flexes just
about every thing that an average extension would want to do. A more
formal article will be coming soon that has a full fledged example along
with a walk through on how to create an extension. I hope this will be
available sometime in mid to late June.
For others reading this post, the slides are available on the
EclipseCon website http://www.eclipsecon.org/2006/Sub.do?id=260.
HTH,
-MDE.
> empty :(
> the presentation file)
> /max
Re: common navigator examples empty ? EclipseCon ? [message #303733 is a reply to message #303453] Sat, 20 May 2006 17:51 Go to previous messageGo to next message
I've started a blog to start providing examples to the community and
solicit feedback. The first example posted is available here
http://scribbledideas.blogspot.com/2006/05/building-common-n avigator-based-viewer.html
-MDE.
Michael D. Elder wrote:
> Hi Max,
> HTH,
> -MDE.
>> the EclipseCon talk about
>> empty :(
>> /max
Re: common navigator examples empty ? EclipseCon ? [message #303740 is a reply to message #303733] Sun, 21 May 2006 06:18 Go to previous messageGo to next message
Hi MDE,
I tried to follow your blog but even though my extension points is equal
to the one in your blog.
I have a feeling that something is missing in the blog text; could you
possible provide a zipped file
of the example ? (the screenshots only show partial information)
> -MDE.
>> Hi Max,
>> just about every thing that an average extension would want to do. A
>> more formal article will be coming soon that has a full fledged example
>> along with a walk through on how to create an extension. I hope this
>> will be available sometime in mid to late June.
>> HTH,
>> -MDE.
>>> empty :(
>>> /max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: common navigator examples empty ? EclipseCon ? [message #303741 is a reply to message #303740] Sun, 21 May 2006 06:41 Go to previous messageGo to next message
correction: My file was *almost* the same ;)
I had made a typo in the viewerid of the viewerContentBinding.
Correcting that and it just works ;)
p.s. is it just me or shouldn't there be an error log entry for invalid id
for e.g. viewerContentBinding ?
Or is there some logging I should enable to get "stupid user errors/info"
from the common navigator ?
> Hi MDE,
>> -MDE.
>>> Hi Max,
>>> example along with a walk through on how to create an extension. I
>>> hope this will be available sometime in mid to late June.
>>> HTH,
>>> -MDE.
>>>> empty :(
>>>> find the presentation file)
>>>> /max
Re: common navigator examples empty ? EclipseCon ? [message #303742 is a reply to message #303741] Sun, 21 May 2006 06:45 Go to previous messageGo to next message
btw. the Error Log still contains the following line:
Contributor org.hibernate.eclipse.navigator.KnownConfigurationsViewer
cannot be created.
which is a message from org.eclipse.ui.views.properties.tabbed.
any idea on how to get rid of that ?
/max
> id for e.g. viewerContentBinding ?
> errors/info" from the common navigator ?
>> Hi MDE,
>> equal to the one in your blog.
>>> -MDE.
>>>> Hi Max,
>>>> HTH,
>>>> -MDE.
>>>>> is empty :(
>>>>> /max
Re: common navigator examples empty ? EclipseCon ? [message #303751 is a reply to message #303742] Sun, 21 May 2006 17:16 Go to previous messageGo to next message
The CN framework has integration with the Tabbed Properties View built
in. It's my impression that the error your seeing simply indicates that
the Tabbed Properties View tried to create a contributor (to it) using
the id of the view part, and was unsuccessful (e.g., no contributor to
the Tabbed Properties View is available with that id). I don't believe
it actually indicates an error condition. I would recommend posting a
bug report to suggest the error message be made a little friendlier
(indicate it's okay) or to remove it.
-MDE.
> cannot be created.
> /max
>> invalid id for e.g. viewerContentBinding ?
>>> Hi MDE,
>>> you possible provide a zipped file
>>>> -MDE.
>>>>> Hi Max,
>>>>> A more formal article will be coming soon that has a full fledged
>>>>> HTH,
>>>>> -MDE.
>>>>>> in the EclipseCon talk about
>>>>>> is empty :(
>>>>>> /max
> --Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: common navigator examples empty ? EclipseCon ? [message #303752 is a reply to message #303741] Sun, 21 May 2006 17:20 Go to previous message
--------------040800060801010609090304
I will be releasing the example to the repo once I have ensured that I
have approvals to do so without affecting the build. I've attached here
for now. If approved, I will release this early this coming week.
As for the id, I'm not sure of what can be done at this point during
development time; the
id is really only used by the extension parsing mechanism, and currently
the PDE schema validation doesn't have a way to indicate how the
attributes of various extensions interact. I could prepare a warning
that would be logged at runtime though. This is how other errors are
logged (like two navigatorContent extensions specifying the same id).
I'd suggest opening a defect if you think this would be useful (but 3.2
is almost shutdown, so it probably won't make it into this release). It
would be easy enough to do for the next release though.
-MDE.
>> Hi MDE,
>>> -MDE.
>>>> Hi Max,
>>>> HTH,
>>>> -MDE.
>>>>> is empty :(
>>>>> /max
Content-Type: text/xml;
name="plugin.xml"
Content-Disposition: inline;
filename="plugin.xml"
<?eclipse version="3.0"?>
<plugin>
<extension
point="org.eclipse.ui.views">
<category
id="org.eclipse.ui.examples.navigator.category"
name="Common Navigator Examples"/>
<view
allowMultiple="false"
class="org.eclipse.ui.navigator.CommonNavigator"
icon="icons/filenav_nav.gif"
id="org.eclipse.ui.examples.navigator.view"
name="Example View"/>
</extension>
<extension
point="org.eclipse.ui.navigator.viewer">
<viewer viewerId="org.eclipse.ui.examples.navigator.view"/>
<viewerContentBinding viewerId="org.eclipse.ui.examples.navigator.view">
<includes>
<contentExtension pattern="org.eclipse.ui.navigator.resourceContent"/>
<contentExtension pattern="org.eclipse.ui.navigator.resources.filters.*"/>
<contentExtension pattern="org.eclipse.ui.examples.navigator.filters.*"/>
</includes>
</viewerContentBinding>
<viewerActionBinding viewerId="org.eclipse.ui.examples.navigator.view">
<includes>
<actionExtension pattern="org.eclipse.ui.navigator.resources.*"/>
</includes>
</viewerActionBinding>
</extension>
<extension
point="org.eclipse.ui.navigator.navigatorContent">
<commonFilter
id=" org.eclipse.ui.examples.navigator.filters.hideNonJavaProject s "
name="Hide non-Java Projects">
<filterExpression>
<not>
<adapt type="org.eclipse.core.resources.IProject">
<test
property="org.eclipse.core.resources.projectNature"
value="org.eclipse.jdt.core.javanature"/>
</adapt>
</not>
</filterExpression>
</commonFilter>
</extension>
</plugin>
--------------040800060801010609090304--
Previous Topic:prob with ant finding junit test class
Next Topic:Eclipse Wizard Page dynamic resize issue.
Current Time: Wed Sep 24 07:56:32 EDT 2025
Powered by FUDForum. Page generated in 0.04881 seconds
