Home » Archived » OHF » STEM integration Mac
STEM integration Mac [message #30315] |
Thu, 14 June 2007 20:44 |
Originally posted by: vega42.gmail.com
--------------090004030801090403070902
I'm migrating this discussion from the [ohf-dev] mailing-list, where I
have discussed problems getting STEM running under MacOsX. After some
initial problems integrating STEM with the SWT I'am able to start
stem.ui for test purposes in the mean time.
However, it appears that although the simulation runs in the
background the ui doesn't refresh properly.
Dan: Your suggestion to turn up the cycle delay in the preference pane
hasn't worked - same situation. Also exporting stem.ui instead of
running it as RCP results in the same problems.
I have attached the stem.iu error log for further insight. There
appears to be I considerable amount of errors logged here although I
have to admit that I can hardly make sense out of half of them.
Perhaps someone (Dan?), who's deeper into the project might understand more.
thx
Vincent
BTW: How far should X11 help? I'm under the impression, that it makes a
difference, if it's on or not (although using swt.carbon), but I would
need to check.
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0";
name="log.log"
Content-Disposition: inline;
filename="log.log"
!SESSION 2007-06-12 18:39:26.844 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_07
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -product org.eclipse.ohf.stem.ui.product
Command-line arguments: -product org.eclipse.ohf.stem.ui.product -data /Users/vincent/Documents/STEM/../runtime-stem.product -dev file:/Users/vincent/Documents/STEM/.metadata/.plugins/org.ec lipse.pde.core/stem.product/dev.properties -os macosx -ws carbon -arch x86 -debug -consoleLog
!ENTRY org.eclipse.osgi 2 0 2007-06-12 18:39:29.420
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:39:29.421
!MESSAGE Bundle update@plugins/org.eclipse.jdt.compiler.apt_1.0.0.v20070510-2000.jar [369] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-12 18:39:29.421
!MESSAGE Missing imported package org.eclipse.jdt.internal.compiler.tool_0.0.0.
!MESSAGE Bundle update@plugins/org.eclipse.jdt.compiler.tool_1.0.0.v_770.jar [370] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-12 18:39:29.422
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.6
!ENTRY org.eclipse.osgi 4 0 2007-06-12 18:39:29.536
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-carbon-3345 or swt-carbon in swt.library.path, java.library.path or the jar file
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:21 9)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:15 1)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:9 43)
at org.eclipse.swt.widgets.Display.create(Display.java:937)
at org.eclipse.swt.graphics.Device.<init>(Device.java:119)
at org.eclipse.swt.widgets.Display.<init>(Display.java:749)
at org.eclipse.swt.widgets.Display.<init>(Display.java:740)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:498)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
at org.eclipse.ohf.stem.core.common.presentation.CoreEditorAdvi sor$Application.start(CoreEditorAdvisor.java:109)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
!ENTRY org.eclipse.osgi 2 0 2007-06-12 18:39:29.545
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:39:29.545
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-12 18:39:29.546
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:39:29.546
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-12 18:39:29.547
!SESSION 2007-06-12 18:50:22.200 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2007-06-12 18:50:25.002
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2007-06-12 18:50:25.024
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:50:25.024
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-12 18:50:25.024
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-12 18:50:25.025
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-12 18:50:25.025
!SESSION 2007-06-13 10:27:11.555 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2007-06-13 10:27:14.257
!STACK 1
java.lang.UnsatisfiedLinkError: PTR_sizeof
at org.eclipse.swt.internal.C.PTR_sizeof(Native Method)
at org.eclipse.swt.internal.C.<clinit>(C.java:24)
!ENTRY org.eclipse.osgi 2 0 2007-06-13 10:27:14.287
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 10:27:14.287
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 10:27:14.288
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 10:27:14.288
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 10:27:14.288
!SESSION 2007-06-13 11:30:19.806 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2007-06-13 11:30:21.462
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2007-06-13 11:30:21.486
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 11:30:21.487
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 11:30:21.487
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 11:30:21.487
!SESSION 2007-06-13 11:56:50.023 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2007-06-13 11:56:51.736
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 11:56:51.736
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 11:56:51.737
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 11:56:51.737
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 11:56:51.737
!SESSION 2007-06-13 12:47:29.441 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2007-06-13 12:47:31.952
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 12:47:31.952
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-13 12:47:31.953
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-13 12:47:31.953
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-13 12:47:31.953
!ENTRY org.eclipse.ui 4 0 2007-06-13 12:47:34.910
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NoClassDefFoundError: org/eclipse/swt/internal/carbon/OS)
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3212)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2956)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ohf.stem.core.common.presentation.CoreEditorAdvi sor$Application.start(CoreEditorAdvisor.java:111)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/internal/carbon/OS
at org.eclipse.ui.carbon.CarbonUIEnhancer.hookApplicationMenu(C arbonUIEnhancer.java:242)
at org.eclipse.ui.carbon.CarbonUIEnhancer.access$2(CarbonUIEnha ncer.java:228)
at org.eclipse.ui.carbon.CarbonUIEnhancer$1.run(CarbonUIEnhance r.java:136)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:155)
at org.eclipse.ui.internal.UISynchronizer$2.run(UISynchronizer. java:126)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 23 more
!SESSION 2007-06-13 12:50:01.004 -----------------------------------------------
!ENTRY org.eclipse.ui 4 0 2007-06-13 12:50:06.156
!STACK 0
... 23 more
!SESSION 2007-06-14 16:21:14.868 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2007-06-14 16:21:19.061
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-14 16:21:19.061
!SUBENTRY 2 org.eclipse.jdt.compiler.apt 2 0 2007-06-14 16:21:19.062
!SUBENTRY 1 org.eclipse.osgi 2 0 2007-06-14 16:21:19.062
!SUBENTRY 2 org.eclipse.jdt.compiler.tool 2 0 2007-06-14 16:21:19.063
!SESSION 2007-06-14 17:03:50.132 -----------------------------------------------
!ENTRY org.eclipse.ohf.stem.ui.ge 1 0 2007-06-14 17:04:33.427
!MESSAGE EXCEPTION java.io.IOException: Server returned HTTP response code: 500 for URL: http://127.0.0.1:56259/STEM/verify: Server returned HTTP response code: 500 for URL: http://127.0.0.1:56259/STEM/verify
!ENTRY org.eclipse.ohf.stem.ui.ge 4 0 2007-06-14 17:04:33.445
!MESSAGE StemKml: Unable to communicate with web server @ http://127.0.0.1:56259
!ENTRY org.eclipse.ohf.stem.ui.ge 4 0 2007-06-14 17:04:33.464
!MESSAGE GoogleEarth Servlet support disabled
--------------090004030801090403070902--
Re: STEM integration Mac [message #30350 is a reply to message #30315] |
Fri, 15 June 2007 11:42 |
since it's kind of quit around here I will try to help myself and let
you know! :)
Soooo, my plan is now to check out a the gtk-engine instead of the
standard MacOsX carbon engine. I figure since I'm dealing with ui
problems here and know, that they don't appear under Linux using gtk
this might be a good idea.
Furthermore I'm aware of other product such as Matlab from Mathworks,
which take this track (also Java-based).
Looking forward to a flourishing discussion regarding my home-grown
problems. ;-)
Vincent
> more.
> thx
> Vincent
> need to check.
Re: STEM integration Mac [message #30386 is a reply to message #30350] |
Fri, 15 June 2007 15:55 |
yay,
I made it. It appears that they're issues regarding the integration of
swt under MacOsX. These can be solved by either patching JavaSDK 1.5 or
switching entirely to JavaSDK 1.6.
After doing latter and instructing Eclipse to use the new version in
Preferences->Compiler everything runs nice and smooth.
I will hence close the related bug-report and in case you guys are
interested in any further information to update your installation
procedures just let me know.
Furhert information can be found on developer.apple.com:
http://adcdownload.apple.com/Java/swt_compatibility_librarie s_for_j2se_5.0_release_4/swtcompatibilityreadme.html
and
http://adcdownload.apple.com/Java/java_se_6.0_release_1_deve loper_preview_6/javase6r1dp6releasenotes.html
although I think you need an account to access these sites.
cheers
Vincent
> you know! :)
> problems. ;-)
> Vincent
>> more.
>> thx
>> Vincent
>> a difference, if it's on or not (although using swt.carbon), but I
>> would need to check.
Re: STEM integration Mac [message #30421 is a reply to message #30386] |
Sat, 16 June 2007 02:54 |
Originally posted by: jthomas119_NOSPAM_.gmail.com
Vincent,
That is great. Thank you for pursuing this.
Sorry that we were not of much help. Dan is on a business trip in
France and I am on vacation in Montana. And we are woefully inadequate
when it comes to MacOS. We almost bought a Mac recently for my wife's
movie editing hobby and now I wish we had. I wish eclipse ran on an
IPhone so I could justify buying one of those. :-)
I will update the Installation guide on the OHF Wiki to indicate that
for MacOS, one should install Java 1.6.
I guess that there are also some needed changes to the product file to
pick up the various macos unique files. Could you send me your MacOS
version of stem.product?
Thanks again.
Vincent David wrote:
> yay,
> and
> cheers
> Vincent
>> Hi,
>> you know! :)
>> problems. ;-)
>> Vincent
>>> understand more.
>>> thx
>>> Vincent
Re: STEM integration Mac [message #30455 is a reply to message #30421] |
Sat, 16 June 2007 20:55 |
--------------090901070509020307030708
John Thomas schrieb:
> Vincent,
Sure. You will find a export of stem.product attached. I think all one
really needs besides the new JavaSDK is the swt.carbon plug-in. Let me
know if you guys are interested in a stand-alone version. I think I
could send you something like this.
Vincent
> Thanks again.
>> yay,
>> or switching entirely to JavaSDK 1.6.
>> and
>> cheers
>> Vincent
>>> Hi,
>>> you know! :)
>>> problems. ;-)
>>> Vincent
>>>> understand more.
>>>> thx
>>>> Vincent
>>>> makes a difference, if it's on or not (although using swt.carbon),
>>>> but I would need to check.
Content-Type: text/xml; x-mac-type="0"; x-mac-creator="0";
name="stem.product_MacOSX"
filename="stem.product_MacOSX"
<?pde version="3.1"?>
<product name="STEM (Incubation)" id="org.eclipse.ohf.stem.ui.product" application="org.eclipse.ohf.stem.ui.CoreEditorAdvisorApplication " useFeatures="false">
<aboutInfo>
<image path="/org.eclipse.ohf.stem.ui/branding/ohf64_64_32.gif"/>
<text>
OHF Spatio-Temporal Epidemological/Event Modeler (STEM)
</text>
</aboutInfo>
<configIni use="custom" path="plugin_customization.ini"/>
<launcherArgs>
<programArgs>-debug -consoleLog</programArgs>
<vmArgs>-Xms512M -Xmx512M</vmArgs>
</launcherArgs>
<windowImages i16="/org.eclipse.ohf.stem.ui/branding/ohf16_16_32.gif" i32="/org.eclipse.ohf.stem.ui/branding/ohf32_32_32.gif" i48="/org.eclipse.ohf.stem.ui/branding/ohf48_48_32.gif" i64="/org.eclipse.ohf.stem.ui/branding/ohf64_64_32.gif" i128="/org.eclipse.ohf.stem.ui/branding/ohf128_128_32.gif"/ >
<splash
location="org.eclipse.ohf.stem.ui"
startupProgressRect="0,413,431,15"
startupMessageRect="10,380,431,20"
startupForegroundColor="FFFFFF" />
<launcher name="STEM">
<solaris/>
<win useIco="false">
<bmp
winSmallLow="/org.eclipse.ohf.stem.ui/branding/ohf16_16_8.bmp "
winMediumLow="/org.eclipse.ohf.stem.ui/branding/ohf32_32_8.bmp "
winLargeLow="/org.eclipse.ohf.stem.ui/branding/ohf48_48_8.bmp "/>
</win>
</launcher>
<vm>
</vm>
<plugins>
<plugin id="com.ibm.icu"/>
<plugin id="com.lowagie.itext"/>
<plugin id="javax.servlet"/>
<plugin id="javax.servlet.jsp"/>
<plugin id="org.apache.ant"/>
<plugin id="org.apache.batik.pdf"/>
<plugin id="org.apache.commons.codec"/>
<plugin id="org.apache.commons.el"/>
<plugin id="org.apache.commons.logging"/>
<plugin id="org.apache.jasper"/>
<plugin id="org.apache.lucene"/>
<plugin id="org.apache.lucene.analysis"/>
<plugin id="org.apache.xerces"/>
<plugin id="org.apache.xml.resolver"/>
<plugin id="org.eclipse.ant.core"/>
<plugin id="org.eclipse.birt.chart.device.extension"/>
<plugin id="org.eclipse.birt.chart.device.svg"/>
<plugin id="org.eclipse.birt.chart.device.swt"/>
<plugin id="org.eclipse.birt.chart.engine"/>
<plugin id="org.eclipse.birt.chart.engine.extension"/>
<plugin id="org.eclipse.birt.chart.ui"/>
<plugin id="org.eclipse.birt.chart.ui.extension"/>
<plugin id="org.eclipse.birt.core"/>
<plugin id="org.eclipse.birt.core.ui"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.macosx" fragment="true"/>
<plugin id="org.eclipse.core.filesystem.win32.x86"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.net"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.compatibility" fragment="true"/>
<plugin id="org.eclipse.core.resources.win32"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.auth"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry" fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.common.ui"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.change"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.emf.edit"/>
<plugin id="org.eclipse.emf.edit.ui"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.http.jetty"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.equinox.jsp.jasper"/>
<plugin id="org.eclipse.equinox.jsp.jasper.registry"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.help.appserver"/>
<plugin id="org.eclipse.help.base"/>
<plugin id="org.eclipse.help.ui"/>
<plugin id="org.eclipse.help.webapp"/>
<plugin id="org.eclipse.jdt.compiler.apt" fragment="true"/>
<plugin id="org.eclipse.jdt.compiler.tool" fragment="true"/>
<plugin id="org.eclipse.jdt.core"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.ohf.stem.core"/>
<plugin id="org.eclipse.ohf.stem.definitions"/>
<plugin id="org.eclipse.ohf.stem.diseasemodels"/>
<plugin id="org.eclipse.ohf.stem.diseases"/>
<plugin id="org.eclipse.ohf.stem.geography"/>
<plugin id="org.eclipse.ohf.stem.jobs"/>
<plugin id="org.eclipse.ohf.stem.jobs.nl1" fragment="true"/>
<plugin id="org.eclipse.ohf.stem.sequencers"/>
<plugin id="org.eclipse.ohf.stem.ui"/>
<plugin id="org.eclipse.ohf.stem.ui.diseasemodels"/>
<plugin id="org.eclipse.ohf.stem.ui.ge"/>
<plugin id="org.eclipse.ohf.stem.ui.nl1" fragment="true"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.osgi.util"/>
<plugin id="org.eclipse.pde.runtime"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.carbon.macosx" fragment="true"/>
<plugin id="org.eclipse.swt.gtk.linux.x86" fragment="true"/>
<plugin id="org.eclipse.swt.win32.win32.x86"/>
<plugin id="org.eclipse.team.core"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.tomcat"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.carbon" fragment="true"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.ide"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.win32"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.update.configurator"/>
<plugin id="org.eclipse.update.core"/>
<plugin id="org.eclipse.update.core.win32"/>
<plugin id="org.eclipse.update.ui"/>
<plugin id="org.eclipse.xsd"/>
<plugin id="org.junit"/>
<plugin id="org.mortbay.jetty"/>
<plugin id="org.mozilla.rhino"/>
<plugin id="org.w3c.dom"/>
</plugins>
</product>
--------------090901070509020307030708--
Re: STEM integration Mac [message #30948 is a reply to message #30735] |
Sat, 23 June 2007 12:56 |
Hey Dan,
just came back from a trip yesterday, so I can reply only now to your
request.
Daniel Ford schrieb:
> I looked at using the new stemMacOS.product file to generate a
release for the Mac, but I'm not being successful...yet. My windows
installation is missing the necessary plugins (e.g.,
org.eclipse.swt.carbon.macosx, etc.).
Additionally to the STEM-plugins I checked out the packages:
org.eclipse.swt
the ...carbon.macosx is deprecated. I'm not aware of any additional RCP
packs. I only needed the basic RC3.3 (called Europe).
If you have any further questions please let me know.
Vincent
> I understand that I need to install the RCP delta pack, but I looked
and could not find that for Europa (not released yet?)
> Does anyone have any insight?
> Thanks
> Dan
Re: STEM integration Mac [message #578978 is a reply to message #30315] |
you know! :)
problems. ;-)
Vincent
> more.
> thx
> Vincent
> need to check.
Re: STEM integration Mac [message #579015 is a reply to message #30350] |
yay,
and
cheers
Vincent
> you know! :)
> problems. ;-)
> Vincent
>> more.
>> thx
>> Vincent
Re: STEM integration Mac [message #579033 is a reply to message #30386] |
John Thomas Messages: 14 Registered: July 2009 |
Vincent,
Thanks again.
> yay,
> and
> cheers
> Vincent
>> Hi,
>> you know! :)
>> problems. ;-)
>> Vincent
>>> understand more.
>>> thx
>>> Vincent
Re: STEM integration Mac [message #579054 is a reply to message #30421] |
> Vincent,
Vincent
> Thanks again.
>> yay,
>> and
>> cheers
>> Vincent
>>> Hi,
>>> you know! :)
>>> problems. ;-)
>>> Vincent
>>>> understand more.
>>>> thx
>>>> Vincent
<aboutInfo>
<text>
</text>
</aboutInfo>
<launcherArgs>
</launcherArgs>
<splash
<solaris/>
<bmp
</win>
</launcher>
<vm>
</vm>
<plugins>
</plugins>
</product>
Re: STEM integration Mac [message #579451 is a reply to message #30735] |
Hey Dan,
request.
org.eclipse.swt
Vincent
> Thanks
> Dan
Current Time: Fri Apr 26 23:07:04 GMT 2024
Powered by FUDForum. Page generated in 0.05573 seconds
