Home » Eclipse Projects » Gemini » Spring MVC with Blueprint Web?
Spring MVC with Blueprint Web? [message #1608898] Mon, 09 February 2015 20:56 Go to next message
Jochen Heintz is currently offline Jochen HeintzFriend
Hi all,
i am trying to get Spring MVC running with Blueprint.
The Controllers working and jsp files getting rendered.
Now i want to style the output with css and i tried
   <mvc:resources mapping="/resources/**" location="/resources/" />
in the application-servlet.xml to ship static content.
Full application-servlet.xml
<beans xmlns="htt(p://www.springframework.org/schema/beans"
	xmlns:xsi="htt(p://www.w3.org/2001/XMLSchema-instance"
	xmlns:mvc="htt(p://www.springframework.org/schema/mvc"
	xsi:schemaLocation="
        htt(p://www.springframework.org/schema/mvc/spring-mvc.xsd
        htt(p://www.springframework.org/schema/beans/spring-beans-3.2.xsd
	 <bean id="test" class="de.test.osgi.controller.ServiceTest">
	 </bean>
</beans>
(I wrote htt(p in the xml because i'm not allowed to write a link inside the text Wink )
web.xml
<web-app version="2.5" xmlns="htt(p://java.sun.com/xml/ns/javaee"
	xsi:schemaLocation="htt(p://java.sun.com/xml/ns/javaee htt(p://java.sun.com/xml/ns/javaee/web-app_2_5.xsd">
	<welcome-file-list>
   <welcome-file>index.htm</welcome-file>
   <welcome-file>index.jsp</welcome-file>
</welcome-file-list>
	<servlet>
		<servlet-name>applicationContext</servlet-name>
		<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
		<load-on-startup>2</load-on-startup>
	</servlet>
	<listener>
			<listener-class>
				org.springframework.web.context.ContextLoaderListener
			</listener-class>
		</listener>
	<servlet-mapping>
		<url-pattern>/</url-pattern>
	</servlet-mapping>
</web-app>
I'm getting this error:
Feb 12, 2015 9:14:58 AM org.springframework.web.servlet.FrameworkServlet initServletBean
SEVERE: Context initialization failed
org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Unable to locate Spring NamespaceHandler for XML schema namespace [htt(p://www.springframework.org/schema/mvc]
Offending resource: ServletContext resource [/WEB-INF/applicationContext-servlet.xml]
	at org.springframework.beans.factory.parsing.FailFastProblemReporter.error(FailFastProblemReporter.java:68)
	at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:85)
	at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:80)
	at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.error(BeanDefinitionParserDelegate.java:318)
	at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1435)
	at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1428)
	at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:185)
	at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.doRegisterBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:139)
	at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:108)
	at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:493)
	at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:390)
	at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
	at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
	at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:174)
	at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:209)
	at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:180)
	at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:125)
	at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:94)
	at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
	at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:537)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:451)
	at org.springframework.web.servlet.FrameworkServlet.configureAndRefreshWebApplicationContext(FrameworkServlet.java:651)
	at org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:599)
	at org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:665)
	at org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:518)
	at org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:459)
	at org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:136)
	at javax.servlet.GenericServlet.init(GenericServlet.java:244)
	at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1284)
	at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1197)
	at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:1087)
	at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:5229)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5516)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:649)
	at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
	at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:109)
	at org.eclipse.gemini.web.extender.WebContainerBundleCustomizer.addingBundle(WebContainerBundleCustomizer.java:49)
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469)
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:1)
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
	at org.osgi.util.tracker.BundleTracker.open(BundleTracker.java:156)
	at org.eclipse.gemini.web.extender.ExtenderActivator$ExtendedWebContainerTracker.addingService(ExtenderActivator.java:59)
	at org.eclipse.gemini.web.extender.ExtenderActivator$ExtendedWebContainerTracker.addingService(ExtenderActivator.java:1)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318)
	at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
	at org.eclipse.gemini.web.extender.ExtenderActivator.start(ExtenderActivator.java:35)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
	at org.eclipse.osgi.container.Module.doStart(Module.java:571)
	at org.eclipse.osgi.container.Module.start(Module.java:439)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Feb 12, 2015 9:14:58 AM org.apache.catalina.core.ApplicationContext log
SEVERE: StandardWrapper.Throwable
Feb 12, 2015 9:14:58 AM org.apache.catalina.core.StandardContext loadOnStartup
SEVERE: Servlet  threw load() exception
I use spring in version 3.2.2 under Equinox Luna
Is there something i am missing?
Kind regards
Jochen
[Updated on: Thu, 12 February 2015 08:23]
Report message to a moderator
Re: Spring MVC with Blueprint Web? [message #1614542 is a reply to message #1608898] Fri, 13 February 2015 10:09 Go to previous message
Hi all,
i found a solution for that particular problem.
I looked into the source code of Spring 3.2 and i found out that i had to provide a mapping for the mvc namespace.
I created a file called spring.handlers in my META-INF directory.
spring.handlers file:
http\://www.springframework.org/schema/mvc=org.springframework.web.servlet.config.MvcNamespaceHandler
Now i can use the <mvc:resource configuration tag without problems.
My application-servlet.xml
<beans xmlns:xsi="htt(p://www.w3.org/2001/XMLSchema-instance"
	xmlns:mvc="htt(p://www.springframework.org/schema/mvc" xmlns="htt(p://www.springframework.org/schema/beans"
	xsi:schemaLocation="htt(p://www.springframework.org/schema/mvc
        htt(p://www.springframework.org/schema/beans/spring-beans.xsd
	<mvc:annotation-driven />
	<mvc:resources mapping="/css/**" location="/assets/css/" order="1"/>
	<bean
		class="org.springframework.web.servlet.view.InternalResourceViewResolver">
		<property name="prefix" value="/WEB-INF/jsp/" />
		<property name="suffix" value=".jsp" />
	</bean>
	<bean id="test" class="de.netpioneer.osgi.controller.ServiceTest">
	</bean>
</beans>
I see in the log that the handler is mapped:
INFO: Mapped URL path [/css/**] onto handler 'org.springframework.web.servlet.resource.ResourceHttpRequestHandler#0'
Kind regards
Jochen
[Updated on: Fri, 13 February 2015 10:10]
Previous Topic:Dependency troubles with Felix and Gemini JPA
Next Topic:Inefficient locking on OSGiInitialContextFactoryBuilder
Current Time: Tue Jun 06 06:21:28 GMT 2023
Powered by FUDForum. Page generated in 0.01350 seconds
