Home » Eclipse Projects » e(fx)clipse » JavaFX in PlugIn project.(Problems with Eclipse IDE.)
icon5.gif  JavaFX in PlugIn project. [message #1608580] Mon, 09 February 2015 11:13 Go to next message
Hello All,
Last time, I've been strugling with running any plug-in project which is using JavaFX and I stucked... I'm getting below exceptions:
!ENTRY org.eclipse.fx.ide.java6 4 0 2015-02-09 16:41:14.001
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.fx.ide.java6 [219]
  Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version>=1.3)(!(version>=1.8)))"
	at org.eclipse.osgi.container.Module.start(Module.java:434)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
org.eclipse.core.runtime.CoreException: Plug-in "MyPlug" was unable to instantiate class "myplug.views.SampleView".
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:63)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:108)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:264)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:302)
Caused by: java.lang.NoClassDefFoundError: javafx/scene/Parent
	at java.lang.Class.getDeclaredConstructors0(Native Method)
	at java.lang.Class.privateGetDeclaredConstructors(Class.java:2658)
	at java.lang.Class.getConstructor0(Class.java:2964)
	at java.lang.Class.newInstance(Class.java:403)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
	... 122 more
Caused by: java.lang.ClassNotFoundException: javafx.scene.Parent cannot be found by MyPlug_1.0.0.qualifier
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
I've tried Eclipse, Eclipse EE, Eclipse RCP (all Luna version) and behaviour was exactly the same.
Simple applications with JavaFX are working without any problem, plugin projects are also working well, but mixing this two things is causing above exception .
Any idea why it is happening ? I will be really grateful for any help.
Thank You.
Re: JavaFX in PlugIn project. [message #1608707 is a reply to message #1608580] Mon, 09 February 2015 13:02 Go to previous messageGo to next message
Do you have the necessary Import-Package directives in your MANIFEST.MF?
It should hold something like
> Import-Package: javafx.animation;version="2.2.0",
> javafx.application;version="2.2.0",
> javafx.beans;version="2.2.0",
> javafx.beans.binding;version="2.2.0",
> javafx.beans.property;version="2.2.0",
> javafx.beans.property.adapter;version="2.2.0",
> javafx.beans.value;version="2.2.0",
> javafx.collections;version="2.2.0",
> javafx.collections.transformation;version="8.0.0",
> javafx.concurrent;version="2.2.0",
> javafx.css;version="8.0.0",
> javafx.embed.swing;version="2.2.0",
> javafx.embed.swt;version="2.2.0",
> javafx.event;version="2.2.0",
> javafx.fxml;version="2.2.0",
> javafx.geometry;version="2.2.0",
> javafx.print;version="8.0.0",
> javafx.scene;version="2.2.0",
> javafx.scene.canvas;version="2.2.0",
> javafx.scene.chart;version="2.2.0",
> javafx.scene.control;version="2.2.0",
> javafx.scene.control.cell;version="2.2.0",
> javafx.scene.effect;version="2.2.0",
> javafx.scene.image;version="2.2.0",
> javafx.scene.input;version="2.2.0",
> javafx.scene.layout;version="2.2.0",
> javafx.scene.media;version="2.2.0",
> javafx.scene.paint;version="2.2.0",
> javafx.scene.shape;version="2.2.0",
> javafx.scene.text;version="2.2.0",
> javafx.scene.transform;version="2.2.0",
> javafx.scene.web;version="2.2.0",
> javafx.stage;version="2.2.0",
> javafx.util;version="2.2.0",
> javafx.util.converter;version="2.2.0",
Tom
On 09.02.15 18:07, Piotr Iksowski wrote:
> Hello All,
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> ... 122 more
> at
> at
> at
> above exception .
> Thank You.
Re: JavaFX in PlugIn project. [message #1609409 is a reply to message #1608707] Tue, 10 February 2015 00:11 Go to previous messageGo to next message
Not sure, but doesn't the error message report an issue regarding the Java version? Do you run your application using Java 8?
Re: JavaFX in PlugIn project. [message #1609426 is a reply to message #1609409] Tue, 10 February 2015 00:27 Go to previous messageGo to next message
No this resolve does tell exactly the opposite - he runs java8! This bundle activates if your version is lower than java8 showing a warning that efxclipse is disabled because it requires java8. I know this is strange nur in the early days of java8 we had many people wondering why efxclipse did not work in their env. I think we should remove this bundle in 2.0.
Re: JavaFX in PlugIn project. [message #1609780 is a reply to message #1609426] Tue, 10 February 2015 05:33 Go to previous messageGo to next message
Solved ! (almost Smile)
Yes, I'm using Java 8. As Thomas wrote, problem was in Manifest.mf (lacking dependencies for JavaFX).
After changes in Manifest.mf all exceptions disapeared apart from the first one about Java version ("org.osgi.framework.BundleException: Could not resolve module: org.eclipse.fx.ide.java6 [219]"). I've made few tests and it turned out that this exception appeares after installing JavaFX plugin in Eclipse and it is thrown every time when I'm running Eclipse Plugin project (even if the project does NOT use JavaFX. So it seems that there are some problems with compability between JavaFX plugin and Eclipse).
Thanks for help !
[Updated on: Tue, 10 February 2015 05:34] by Moderator
Re: JavaFX in PlugIn project. [message #1609848 is a reply to message #1609780] Tue, 10 February 2015 06:28 Go to previous messageGo to next message
No this plugin is NOT wrong nor BUGGY but works as designed! It is there
when you installed e(fx)clipse because all TOOLING bundles require Java8.
So when Java8 was not default for most people to run their IDE people
have been wondering why they did not see all the e(fx)clipse tooling
stuff (including very seasoned devs at EclipseCon Tutorials) although
the bundles where installed appropriately through p2.
The bundle refusing the start under Java8 is a bundle who would bring up
a dialog telling you that you are running e.g. on Java 5 / 6 / 7 and the
tooling will not be functional (including to disable the warning for the
future!).
It's unfortunate that Equinox croaks with such a big error message since
Luna and as I already replied to Dirk we might now safely remove this
helper bundle and assume that people are smart enough to run their IDE
with Java8 if they are doing JavaFX dev.
Tom
On 10.02.15 11:33, Piotr Iksowski wrote:
> Solved ! (almost :))
> Yes, I'm using Java 8. As Thomas wrote, problem was in Mainmfest.mf
> After changes in Manifest.mf all exceptions disapared apart from the
> Thanks for help !
Re: JavaFX in PlugIn project. [message #1784967 is a reply to message #1609780] Fri, 06 April 2018 07:15 Go to previous message
Dear,
it seems I am having the same issue,
how can I add the JavaFX to Manifest, please ???
Previous Topic:Maven cannot compile application
Next Topic:Can we use JUnit 5 with e(fx)clipse?
Current Time: Mon Jun 30 17:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.03429 seconds
