| ATL conforms to MOF? [message #30208] |
Fri, 06 April 2007 05:36  |
Originally posted by: not.provided.info
While looking for ATL documentation I have found (picture), that shows ATL
conforms to MOF - how it can be? As I understand, conformance to MOF
means, that language (ATL it this case) is specified through the MOF
(EMOF?) elements, so there should exist ATL UML metamodel :) ATL guide
describes ATL in informal way - definitions, syntax, semantics is provided
in a natural way.
| Re: ATL conforms to MOF? [message #30245 is a reply to message #30208] |
Fri, 06 April 2007 09:26   |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Gediminas,
> ATL conforms to MOF - how it can be? As I understand, conformance to MOF
> provided in a natural way.
ATL is a DSL (domain-specific language) for defining M2M
transformations. Its abstract syntax (i.e. its concepts) is defined by a
metamodel (M2 level).
Like any metamodel (i.e. like UML which is another metamodel), it
conforms to the metametamodel (MOF -> M3 Level).
So, ATL transformations can be expressed as models that conform to the
ATL metamodel (which conforms to MOF) in a similar way that UML class
diagrams (for instance) can be expressed as models that conform to the
UML metamodel (which also conforms to MOF).
I hope these some information may help you.
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
| Re: ATL conforms to MOF? [message #31324 is a reply to message #30245] |
Fri, 13 April 2007 09:58   |
Agree, that ATL is DSL, but have you seen it's metamodel ;) ? I haven't
(and would love to see it), althought read all accessible ATL
articles/guides/tutorials. By metamodel I mean UML class diagram, because
ATL metamodel conforms to MOF :) Conformance to MOF means, that
model/metamodel must be expressed through the MOF/UML concepts.
From the formal point of view, metamodel can conform to anything, MOF
would be only one possible option. But ... MDA requires, that metamodels
MUST conform to MOF. And ATL supports MDA style transformations and I'm
happy of this :)
Hugo wrote: ------------------------------------------------
ATL is a DSL (domain-specific language) for defining M2M transformations.
Its abstract syntax (i.e. its concepts) is defined by a metamodel (M2
level).
Like any metamodel (i.e. like UML which is another metamodel), it conforms
| Re: ATL conforms to MOF? [message #31447 is a reply to message #31324] |
Fri, 13 April 2007 10:11   |
Originally posted by: mikael.barbero.gmail.com
ATL metamodel is in the org.eclipse.m2m.atl.engine plugin from the
beginning (org/eclipse/m2m/atl/engine/resources/ATL-0.2.ecore)
You can see it here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmt/ATL /org.atl.eclipse.engine/src/org/atl/eclipse/engine/resources /ATL-0.2.ecore?revision=1.6&root=Technology_Project& view=markup
Mikael
> because ATL metamodel conforms to MOF :) Conformance to MOF means, that
> happy of this :)
Mikaël Barbero - PhD Candidate
2, rue de la Houssinière
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
| Re: [ATL] ATL conforms to MOF? [message #31687 is a reply to message #31480] |
Sat, 14 April 2007 12:28  |
Well, I do not think there is any requirement that every MOF metamodel
must be represented as a class diagram :-).
Anyway, even the UML metamodel itself is not represented as *a* class
diagrams but as many.
As for the metamodel of ATL, it is of course defined in KM3, not using a
UML tool. Mikaël pointed you to the Ecore definition of ATL, from which
you can get the KM3 back.
We should probably also put it in the KM3 zoo, so that it appears in the
mirror zoos. This would for instance make a UML class diagram version of
the ATL metamodel automatically available :-).
However, you may already apply these transformations yourself as there
are all already available.
Frédéric Jouault
Gediminas wrote:
> nice, why ATL metamodel as a UML class diagram doesn't exist in ATL
> documentation?
> so ATL is really MOF compliant ;)
FUDForum. Page generated in 0.03991 seconds
