Home » Eclipse Projects » Eclipse Platform » Java template within a string
Java template within a string [message #300574] Sun, 12 March 2006 23:58 Go to next message
Originally posted by: relaxedrob.remove.this.optusnet.com.au
Hi All,
I use WSAD 5.1 at work and I have the following Java template (Windows >
Preferences > Java > Editor > Templates) defined:
[" + ${cursor} + "]
This is great for me to break up a string easily and insert some
variable.. It provides a shortcut for doing something like this:
System.println("Value of x is [" + x + "].");
My problem is that under Eclipse 3.1.1, I can't use Java templates from
within a string anymore! Is this something I can control with a setting
somewhere? It is a shame to drop this template just cos' I am in a string!
Any help most appreciated!
Rob
Re: Java template within a string [message #300599 is a reply to message #300574] Mon, 13 March 2006 11:03 Go to previous message
Templates are not available in strings. However, you can do what you
want by using "Quick Assist": select the string you want to extract and
press Ctrl+1, then choose "Pick out selected part of the string".
-tom
Robert Mark Bram wrote:
> Hi All,
> [" + ${cursor} + "]
> Rob
Previous Topic:Unused imports are not reported correctly by 3.1.2
Next Topic:Avoid duplicate menu items
Current Time: Fri Sep 12 01:52:21 EDT 2025
Powered by FUDForum. Page generated in 0.03819 seconds
