Re: [TENEO] Possible performance Issue in IdentifierCacheHandler [message #1602031 is a reply to message #1597810] |
Thu, 05 February 2015 09:22 |
Hi Lukas,
Yes purging should be single threaded for sure. Can you create a bugzilla for this, and if possible attach a patch for it?
Which version of Teneo are you using?
gr. Martin
On 02-02-15 16:21, Lukas Zaruba wrote:
> first let me thank you for the Teneo project, it is a great piece of work!
> and here comes the issue:
> Using Teneo under high load we have discovered (using profiling tools and thread dumps) that purging of the cache on
> each 100 insertions causes frequent concurrent purging of the map.
> What I think happens is a thread invokes the
> org.eclipse.emf.teneo.hibernate.mapping.identifier.IdentifierCacheHandler.setID(Object, Object) method, with condition
> on line 115 resolving as true. It starts purging of the map.
> Other threads goes in the same path and also resolves the 115 condition as true because the previous thread haven't
> finished the job. The second thread also starts purging...
> Same scenario can happen with versions cache.
> As the map is an instance of ConcurrentHashMap ConcurrentModificationException is not thrown and both threads are
> purging the map simultaneously. If there is a heavy load and a lot of threads hit the purging before the counter is
> cleared to zero (line 163), it can heat the CPUs to 100% for a long time.
> Our temporary solution was to recompile the class with the configurable (by System.getProperty(String, String) value of
> the PURGE_TRESHOLD constant which we set to 15000. Since this change has been introduced there were no symptoms of this
> problem. But I don't think it is the complete solution. Probably only one thread should hit the clearing part in a some
> kind of the synchronized block, clear the counter and than start the purging. I believe that the configurable value of
> the PURGE_TRESHOLD is also a valid idea - our application has 20GB of RAM available so I don't mind having the cache of
> 500MB if it increases the performance.
> Can you please give us some feedback on this issue - if it is valid and if maybe there is a better and cleaner solution
> to the described problem than the one we introduced?
> Thank you!
> Cheers, LZ
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03191 seconds
