Home » Eclipse Projects » Eclipse Platform » JFace Wizard title Icon
JFace Wizard title Icon [message #299374] Wed, 15 February 2006 14:21 Go to next message
Originally posted by: rynop2000.hotmail.com
How do you set the icon in the title for a jface wizard?
The image below shows the white square next to "Hotel"
http://www.java2s.com/images/HotelReservation.PNG
How do you change this icon??
Also, how do you get a jface wizard to show up as an entry in your taskbar (in addition to your main shell)?
thx in advance
Re: JFace Wizard title Icon [message #299380 is a reply to message #299374] Wed, 15 February 2006 16:39 Go to previous messageGo to next message
i'm not sure you can. normally the icon is the same as
the icon of the application window. if you are creating
a rcp application you can set the application window icon
by creating a product configuration and setting the icon
you want in the branding page. this icon will then also be
visible in the wizard window...
nick
> thx in advance
Re: JFace Wizard title Icon [message #299388 is a reply to message #299380] Wed, 15 February 2006 18:02 Go to previous messageGo to next message
I figured out the icon part. You just have to statically assign an image to the WizardDialog class...
WizardDialog dlg = new WizardDialog(shell,newConvertWizard());
WizardDialog.setDefaultImage(new Image(Display.getDefault(),"path/to/image.jpg"));
Any idea on how to get the wizard to show up in the taskbar??
Re: JFace Wizard title Icon [message #299389 is a reply to message #299388] Wed, 15 February 2006 18:21 Go to previous messageGo to next message
what exactly do mean with taskbar? the windows taskbar?
Re: JFace Wizard title Icon [message #299621 is a reply to message #299389] Tue, 21 February 2006 07:43 Go to previous message
Originally posted by: miguelbravoyubero.gmail.com
I've tried to put my WizardDialog application into Windows taskbar too,
and I didnŽt obtained any result.
Using an ApplicationWindow to show the WizardDialog is a (bad) solution. I
didnŽt found any more
Previous Topic:ICompositeOperation
Next Topic:toolttip for closing editors and views
Current Time: Tue Sep 02 19:04:56 EDT 2025
Powered by FUDForum. Page generated in 0.02449 seconds
