Re: How do I add my feature to the Eclipse About dialog? [message #299242 is a reply to message #299238] |
Mon, 13 February 2006 14:02 |
Daniel Krügler Messages: 853 Registered: July 2009 |
Yevgeni wrote:
> Alex Blewitt wrote:
>> You need to have a feature, for a start :-) The feature will contain
>> your plugin that you've written.
>> You'll need a separate 'branding plugin', and definitions in the
>> branding plugin that specify what icon to use. There's a good write up
>> at:
>> http://eclipse.pookzilla.net/archive/2006_01_01_archive.php
>> Alex.
> Alex,
> I have created a plug-in and plug-in-feature, but I didn't see me
> feature image button. Do I export my feature using the Eclipse Export
> Wizard?
If you have the standard workspace, you will not see the feature button
until you have the exported product.
I've heard that you could enforce this button during normal development
time, if you have prepared the workspace for a feature-based startup
(Its activation occurs by selecting the 2nd radio button of the plug-in
tab of the run configuration), but my first attempts trying that
approach failed (I have to confess, that I only tryied it once and shortly).
HTH,
Daniel Krügler
Re: How do I add my feature to the Eclipse About dialog? [message #299244 is a reply to message #299238] |
Mon, 13 February 2006 14:10 |
Originally posted by: eclipse.bettsockentraeger.de
Be sure to erase all configuration data from your workbench runtime
since there seems to be some caching issues involved with the feature
stuff.
>> at:
>> Alex.
> Alex,
> Wizard?
> Yevgeni
FUDForum. Page generated in 0.40892 seconds
