Home » Eclipse Projects » Eclipse Platform » JavaUI.getWorkingCopyManager() => NullPointerException
JavaUI.getWorkingCopyManager() => NullPointerException [message #298831] Mon, 06 February 2006 05:05 Go to next message
Originally posted by: timbo.web.de
when I call this methode, it throws a NullPointerException. Can anybody
help me?
Thx Tim
Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298875 is a reply to message #298831] Mon, 06 February 2006 14:16 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Are you running under Eclipse? This method is only valid when running as
an Eclipse plugin.
Tim wrote:
> help me?
> Thx Tim
Rich Kulp
Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298892 is a reply to message #298875] Tue, 07 February 2006 04:31 Go to previous messageGo to next message
> an Eclipse plugin.
Yes, I'm running this method in a plugin, I created a view, which should
access the WorkingCopyManager.
JavaPlugin.getDefault().getWorkingCopyManager();
also doesn't work
Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298919 is a reply to message #298892] Tue, 07 February 2006 10:15 Go to previous messageGo to next message
I don't know why you are getting an NPE, but you shouldn't be using
JavaPlugin. That is an internal class. You should be using:
This is the API way of getting it.
However, this begs the question because under the covers this method
does JavaPlugin.getDefault().getWorkingCopyManager().
What line exactly gives the NPE? What does the stack trace say. If it
says that JavaPlugin.getDefault() return null, then this shouldn't
happen because that can only happen if the jdt ui plugin did not
initialize correctly.
So what is in your .log file, what stack trace?
Rich Kulp
Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298924 is a reply to message #298919] Tue, 07 February 2006 11:29 Go to previous messageGo to next message
when i call JavaUI.getWorkingCopyManager() I get this exception
!ENTRY org.eclipse.ui 4 4 2006-02-07 17:01:58.686
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-02-07 17:01:58.701
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.jdt.ui.JavaUI.getWorkingCopyManager(JavaUI.java: 616)
test.plugin.TestWorkingCopyManagerAction.run(TestWorkingCopy ManagerAction.java:31)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:85)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:58)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:60)
at java.lang.reflect.Method.invoke(Method.java:391)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298932 is a reply to message #298924] Tue, 07 February 2006 13:44 Go to previous messageGo to next message
What version of Eclipse and JDT are you using because my Eclipse/JDT is
I20060131 and JavaUI line 616 is no where near the
getWorkingCopyManager class.
But looking at the code I'm willing to bet it is because
JavaPlugin.getDefault() is returning null.
There is something funny about your setup. Can up bring up a straight
java editor? Does that work in your setup?
> !STACK 0
> at
Rich Kulp
Re: JavaUI.getWorkingCopyManager() => NullPointerException [message #298974 is a reply to message #298924] Wed, 08 February 2006 11:23 Go to previous message
Originally posted by: daniel.megert.eclipse.org
Does your plugin.xml or manifest.mf declare to depend on
org.eclipse.jdt.ui? Are there any other messages in .log?
Dani
> !STACK 0
> at
> at
> at
> at
> at
> Code))
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:Team Synchronize doesn't respect CVS module file list
Next Topic:ICompilationUnit from active Editor
Current Time: Sun Nov 09 13:10:37 EST 2025
Powered by FUDForum. Page generated in 0.06264 seconds
