Home » Eclipse Projects » Eclipse Platform » Keyboard shortcut to cut line
Keyboard shortcut to cut line [message #298649] Thu, 02 February 2006 00:44 Go to next message
Originally posted by: nomail.email.com
Is there a keyboard shortcut in Eclipse to cut a line?
Can I assign a key combination to do this?
Ctrl-D works well if you just want the line gone but it does not help if
you want to paste it somewhere else.
alt-arrows works ok if you are only moving a couple lines away in the same
editor but it is inconvenient most of the time
I got used to the speed of vi, this is the one feature I miss the most.
As a work-around is there a keyboard shortcut to select the current line
no matter where you are in it?
My current method is cumbersome:
1. press home key
2. Shift-End
3. Ctrl-X
There has to be a better way?
thank you.
Re: Keyboard shortcut to cut line [message #298653 is a reply to message #298649] Thu, 02 February 2006 04:00 Go to previous messageGo to next message
Originally posted by: daniel.megert.eclipse.org
someone wrote:
> Is there a keyboard shortcut in Eclipse to cut a line? Can I assign a
The 'Cut Line' command exists but is not bound out of the box. You can
assign a key binding on the 'Keys' preference page. The command is in
the 'Text Editing' category.
Dani
> if you want to paste it somewhere else.
> same editor but it is inconvenient most of the time
> line no matter where you are in it?
> 1. press home key
> 2. Shift-End
> 3. Ctrl-X
> thank you.
icon14.gif  Re: Keyboard shortcut to cut line [message #1754475 is a reply to message #298653] Sat, 18 February 2017 05:58 Go to previous message
Very nice tip.
It took me a while and googling to find out the "Keys" page. So just adding just in-case someone might need it.
My eclipse version: Eclipse Mars
Go to Menu "Window > Preferences > General > Keys".
Search for "Cut Line" and set binding of your choice. In my case I did "Alt + X".
In drop down for When I chose "In Windows" (which was default)
Paste was already setup.
Previous Topic:Detect missing view
Next Topic:Platform changes not persisted on Mac OS X Sierra 10.12.3
Current Time: Tue Sep 02 19:04:54 EDT 2025
Powered by FUDForum. Page generated in 0.02873 seconds
